Posts: 974 |
4 guage wire should do it...but if you have the money I would go 2guage or 0 guage (I/O)
Posts: 3,732 |
i got a 200 amp alternator, but all stock wiring. i also got a red top
my 400 W amp dims my ligs a tiny bit at idle, but rev it up a bit and no dimming at all
Russell
Oval Port 3L Nearly Done
Posts: 511 |
I think i'm gonna try a 3 farad cap. I think its the fact that my amp is 1000 watts rms at 1 ohm. we'll see what happens after that. oh yea, that optima battery i got died while driving. I put my old battery in, started right up. So I take the optima back to autozone, they test it, and it turns out its a bad battery. Guy said its the first one he's seen. Didn't get another one tho. stayin stock right now.
AIM...BKapp17
98 T-red SVT
Steeda
Gutted Pre-cats, no resonator
Painted Dash
Angel Eye Fogs
Painted Chrome ring / headlights
Looking for a t-red pre98 trunk lid
Posts: 8,301 |
Originally posted by Kappa2006: I think i'm gonna try a 3 farad cap. I think its the fact that my amp is 1000 watts rms at 1 ohm.
What amp do you have? Are you running it at 1 Ohm? You do know that you are probably never actually getting a full 1000 watts when you are playing music. Different notes and frequences (sp?) require different amounts of power. At least thats how I understand it, although there are much more educated people on here. Rule of thumb is 1 farad for every 1000 watts. IMO 3 farads is overkill.
Case in point- I have a mono amp rated at 300 watts @ 4 Ohms. I have a fuse in the fuse block rated 10 amps lower than I should and have never blown it, and I play my music pretty loud. I just never use the full power of the amp. My sub would blow or sound like crap before then.
Not trying to start anything, just giving my opinion
-Ken V.
psycho_bass@hotmail.com
Posts: 974 |
well like I have stated earlier upgrading stock wiring (I think it is 8 gauge) to 4 or 0 gauge will do wonders. I have a soundstream that puts out 900 watts RMS @ 4 ohm and a Crunch amp that is 400 watts rms @ 4 ohm. For our vehicles you will never have to upgrade the alternator, and stock batteries should be fine as well. I say before trying anything else to redo the wiring, cause I am almost positive it will take care of it.
Posts: 6 |
Ditch the Cap. All a cap is a added current draw to your already stressed electrical system.See if that helps.
Posts: 1,224 |
Originally posted by PoorBoy: Ditch the Cap. All a cap is a added current draw to your already stressed electrical system.See if that helps.
Ummm...no. A cap can only help. Caps smooth out the current draw.
The majority of all dimming problems are due to bad connections and wire that is too small.
A car battery can supply an insane amount of current for short bursts. With an Optima, 4AWG wire, and good connections, you should have no dimming problems.
HTH, BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
