#921309 04/06/04 05:40 PM
E
E
3 quarts of appropriate fluid. The classic tranny cocktail calls for synthetic ATF. Mobil 1 and Redline ATF work well. Yes, that's ATF, as in Automatic Transmission Fluid. Recently, many have tried Redline MTL, which is a synthetic gear lube that matches the specs for this transaxle. Redline will point out that MTL is not recommended for this application, but those that have tried it have said it works better than the other fluids available, including Ford's synthetic "honey" colored fluid. Ford's fluid (part #XT-M5-QS) runs nearly $20/qt, so MTL is quite attractive. Another option is ATF+3, a Chrysler spec'ed ATF that has the friction modifier already in it. It is much cheaper than the synthetics, but will require more frequent changes. In theory, any 75W90 gear oil will work as long as it is not rated GL-5, which contains additives that will damage the internals. GL-4 is the spec to satisfy for fluids.
Obviously this is from the how-to, so which do you perfer personally-mobil 1 ATF or Redline MTL?
"God Got a Good One" 1982-2004 I love you JLM!
#921310 04/06/04 09:08 PM
Redline.
In my tranny with 80k miles on it, I installed the Mobil 1 ATF + FM. Within 2 months my third gear syncros were gone. Coincidence or not, I don't know, but I've been happy with MTL in my new trans.
#921311 04/07/04 01:18 AM
E
E
I used the Redline, and I couldn't be happier. Now that the weather has warmed up, it shifts sooooo smooth. It's like night and day. I still had the sticking going into first when it was cold out, but only for a min or two.
2000 CSVT Silver Frost: #942 of 2150 HID Projectors and Fog Light Mod, Optomized TB, MSDS headers 2003 Silverstone Z
#921312 04/07/04 02:34 PM
E
E
Thanks guys, redline can be bought at just about any performance shop, right
#921313 04/07/04 03:05 PM
E
E
I wish... I drive past Summit Racing on my way home from school, so I got it there. $7.95 a quart. You can get it online too.
#921314 04/07/04 07:25 PM
When i put my new quaife in used ford atf for the first 500 miles then switched to redline...shifs great...couldn't be happier.
Roz
#921315 04/11/04 12:43 AM
E
E
Just finished changing the fluid. I used the Redline MTL and even though the old fluid only had 3,000 miles on it(Just replaced clutch) I can still feel a difference.
