Posts: 407 |
Anyone have a really good window cleaner you'd recommend? I put Rain-X on two years ago and now want to get it off. It leaves that haze whenever you use the wipers. I already tried the vinagar & water mix and it didn't work.
2000 SVT Black & Blue #205 of 2150 Kenwood Head Unit
2001 SR5 4 Runner 4x4
Posts: 216 |
Eagle one makes a good, ammonia free cleaner that works great if you have tint. Try applying another coat of rain-x, I've never seen that haze! I think its a matter of buffing it off.
2000 Contour SE V6 ATX (White) K&N Moose fixed finally! Dunlop SP Sport A2's Sylvania Silver Stars (low and hi) Lots more coming!
Posts: 401 |
Same advice here- sometimes you can go to a detail shop and order that really good stuff in the can. I have rain x on my car from the previous owner- just cleaned the winshield really well and buffed it and it works like new. The dealership told me that they use orange clean to strip the windows at the lot. it appears to get the acid rain stains off the windshield.
99 SE Sport 2.5 Duratec Spruce Green Metallic.. Aesthetic Only.... For Now
...the closest I will ever get to having a Turbo will be the Gillete Mach 3 variety!!!
Posts: 1,225 |
Stoner's auto glass cleaner, it comes in a can and you can find it at any auto store. Cleans really well and doesn't streak at all.
Ryan
Latest Mod: Mirko Splitter
Posts: 39 |
Would not have believed this until someone showed me. Use a high grade steel wool on the glass, but be careful not to get too close to the edge of the trim/paint. It does wonders.
Chris
Posts: 2,112 |
any abrasive car polish will take the Rain-X right off. 3M has several, Meguiars, etc. I don't think Zaino would work.
Posts: 4,585 |
Originally posted by Krafty: Stoner's auto glass cleaner, it comes in a can and you can find it at any auto store. Cleans really well and doesn't streak at all. www.invisibleglass.com $33 shipped for a case of 12 cans. Or, that 000 steel wool does work. Zaino will not strip anything - non-abrasive. Or
Posts: 677 |
If it's good enough for window washers....it's good enough for me....TSP! (Trisodiumphosphate) and water.
98.5 SE Sport badgeless, MTX, KKM, SVT exhaust with resonator intact. 1985 Z51 Vette with many mods. Only used when the Tour appears to be outclassed.
Posts: 98 |
For the outside only (could use inside, but it is rather messy) I use: Strip It windshield cleaning compound, by Wiper Mates. Billed as a "windshield restorer" It's like an old fashioned paint rubbing compound for glass.
This will strip off old acid rain/hard water spots, so I'm sure it will take off the old Rain-X as well. Then I would re-apply the Rain-X, making sure you buff it sufficiently. A final buff with a misted (lightly damp) towel helps.
After that, and for the inside, I second the recommendation of the Invisible Glass product. Great stuff.
Dave
98.5 SE/sport/MTX Brembo rotors w/KVR front and Mintex A/F rear Pro-Flow 75mm MAF w/KKM filter-Nice! Mobil 1/K&N oil ES MM inserts waiting-I can't get the bolt loose...need a bigger breaker bar:( Aussie Bar and Euro ST200 struts soon! Major mods to stereo system Clarion 9255 All Phoenix Gold processors/MPS amps! Vifa/Adire drivers
Posts: 3,331 |
Originally posted by APT: Originally posted by Krafty: [b]Stoner's auto glass cleaner, it comes in a can and you can find it at any auto store. Cleans really well and doesn't streak at all. www.invisibleglass.com
Or[/b]We have a winner. I suggest you pick a few nice microfiber towel from www.neatitems.com there is no other way to clean glass. -Antonio
99' SVT 86' Toyota Pickup Beater - Tha Daily Driver
