#919888 04/05/04 06:11 AM
I am Canuckian
I am Canuckian
OK I have a wack of amber LEDs. I pulled apart a truck tailight that was supposedly shot. They are 12V as confirmed by my computer power supply. (to lazy to go outside in the cold.) Now aside from new turn signal indicators that I wish to fab into my rear view mirrors where else can I make use of these. I wish they were a different color but free tends to limit options. Ideas?
Green 96 mystique gs 4cyl mtx 16.9 in the 1/4 mile @102500 miles 95SE in Midnight Red MTX MSDS headers and y-pipe SVT exhaust SVT UIM Optimized se TB. Full pre 98 SVT body kit 15.741 @ 87.73mph :)
#919889 04/05/04 02:02 PM
if you only held the LEDs in for a second, that might be why you see them at 12v, try powering them with a 5v wire, or the 3v wire from your comp. If the LED is getting hot when using the 12v, even a tiny bit, its over powering, since its from a tail light chances its 12v.
95 SES Sold 99 SE Sport Sold 99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
#919890 04/05/04 05:38 PM
I am Canuckian
I am Canuckian
Hmmmm interesting. Hadn't thought of that. Which computer wire is 3v?
#919891 04/05/04 05:42 PM
I am Canuckian
I am Canuckian
You are right they over heat. Anything I can do to make them work still?
#919892 04/05/04 10:00 PM
9
Resistor. 280 Ohms work, sometimes like a 500 ohm. Resistor goes on the positive lead.
God graced us with intelligence, let's use it.
#919893 04/05/04 11:10 PM
I am Canuckian
I am Canuckian
First I need to verify the voltage of these though right? I do still have the resistors that came with the led lights. Not sure what is what though as there was more then one I think. Will it matter how many LED's are hooked up at once? Or will one resistor work for however many I run on a line of them?
#919894 04/06/04 02:34 AM
don't remember exactly, ohh wait, sorry the 3v is the processor. can't plug into that one.
#919895 04/06/04 02:58 AM
I am Canuckian
I am Canuckian
I'm lost.
#919896 04/14/04 06:15 PM
Best way is to use a resistor for each because i'm guessing the resistors that they gave you won't handle a very high power. Just branch the hot lead into parallel with each diode,resistor setup in series and should run fine.
Joel Falkenberg
