Here's the problem. Sunroof motor stopped working. Took it apart, gears and everything are fine. Manually closed sunroof so it was closed. Problem is, when it stopped working, i could press the button and there would be drag on the electrical system. Meaning it had power to the switch. When i re-installed the motor, all wires are attached, my DVM says i have power to the switch, but there is no drag on the electrical system now. Is there a fuse location for the sunroof? My manual has no description for a fuse. Where would it be located? I know where the fuse box is under the dash so thats not a problem. Any help here would greatly be appreciated. On one of my search inquiries, i found 1 reply where they said it was the #16 fuse, but that is for the ignition, not the sunroof. I have a 1998 CSVT, please help me fix this small problem. Thanks.
