Posts: 375 |
ok i have been seeing some post about these and i was just curious if they are 100% needed. the reason that i ask is that my OZ Superleggeras did not come with any. am i ruining my wheels by drving on them without these rings? please help..
Alex T.
98.5 Silver Frost CSVT #5510
05 Nissan Frontier Nismo 4x4 6 speed
85 Bronco II 6" lift 302 swap
Posts: 3,496 |
Some wheels are hub-centric others are lug-centric. I would suspect your wheels are lug-centric as you do not have the hub-centering pieces.
Mine are very small black plastic rings that fit into the back side of the wheel. Double check to see if you have the small ring inside your wheel by pulling it off.
Posts: 3,867 |
If the center bore of the wheel matches your hub diameter exactly, you don't need the rings. If there is any gap at all, you need them.
Any wheel that needs them is not hubcentric. The ring simply allows the lugcentric wheel to be properly centered on the hub while you tighten the lugs.
Function before fashion.
'96 Contour SE
Posts: 4,639 |
my wheels didnt come with the black rings. i had to order them. the center inside of the wheel will have a slight inward recess where the hubcentric ring pops on allowing the wheel back to be flush to the hub
Hugo AIM:omegazodiac
Posts: 375 |
where exactly would i order them from?
Alex T.
Posts: 1,210 |
3.0 14.392@97.237 2.302 60ft
OEM 4-bolt LCA's $105 each
Watch me go
Posts: 3,195 |
Originally posted by slolx50: where exactly would i order them from?
your best bet would be to order them from your wheel manufacturer/dealer so they fit your wheel/hub perfectly...
I just got a set for my wheels from the mfr...$25, they were more than willing to help w/o sending me to one of their dealers. It might be cheaper for you that way too.
1999 Sportage 4x4...don't go there, it was free
....______o_o
.../_l l__\____\
..|--l l__----[]\|/[]
.....................oo
=( )_)----( )_)--)_)
