Posts: 2,807 |
I just think it would look better if it went from one side of the dash to the other and covered all of the area from the vents to the windshield, similar to the 98's and earlier. It just looks like a half a$$ed attempt IMO, by that I mean the design and not the install which looks professional.
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 36 |
LAST YEAR THERE WAS A RECALL ON THE DASHBOARD. I HAD MY 99 SE SPORT DASH REPLACED AT NO CHG. DUE TO THE RECALL. MINE WARPED AS WELL.
Posts: 2,807 |
Originally posted by hiddendragonse: LAST YEAR THERE WAS A RECALL ON THE DASHBOARD. I HAD MY 99 SE SPORT DASH REPLACED AT NO CHG. DUE TO THE RECALL. MINE WARPED AS WELL.
Recall has expired. They stopped replacing dashes and started fixing them.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
Posts: 1,505 |
looks better then mine i have that too on my 99 but they put the strip over that and pop ribbit it looks very sloppy
1999 Ford Contour SE Zetec with 137k miles.
AIM Name: ContourAlf
Yahoo IM: Contour_Freak
Posts: 9 |
The dash on my 99 svt was warped when I bought it. Dealer replaced it under warranty but it took three overnight stays for them to get it right. They kept ordering the wrong one apparently.
99 svt, green/tan, K&N filter, Pioneer sound, plain sail panels
Posts: 18 |
Do you have to take the dash out to perform the Ford fix? If so, how hard is it to take out the dash?
Posts: 2,807 |
Originally posted by FJI: Do you have to take the dash out to perform the Ford fix? If so, how hard is it to take out the dash?
My understanding is that you only need to partially remove the dash for the Ford fix. It does not need to come completely out of the car, although if completely removed it would be easier to work with I would think. It's large and awkward to handle inside of the car.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
Posts: 4,149 |
I've done it; you'll actually save time and get better results by removing the dash completely. Do a search for dash warp, tons of info out there on what's involved.
-- 1999 SVT #220 --
Posts: 1,016 |
I wasn't able to pull the dash from the car completely, although I wish I could've. The wiring that runs down the passanger door couldn't be removed without tons of work... or so it seemed. Either way, mine's done.
2000 CSVT Silver Frost: #942 of 2150
HID Projectors and Fog Light Mod, Optomized TB, MSDS headers
2003 Silverstone Z
Posts: 2,807 |
Originally posted by epattonm: I wasn't able to pull the dash from the car completely, although I wish I could've. The wiring that runs down the passanger door couldn't be removed without tons of work... or so it seemed. Either way, mine's done.
IIRC there are 3 plugs and some ground wires there, not much work at all.
99 CSVT Green/Tan
# 84 of 2760
75,000Km
96 Contour GL
