Posts: 135 |
Im gonna be going on a trip for FLA (from Toronto, Ontario) and I know my fluid is due for atleast a drain and fill. but I was wondering if it is advisable or discouraged to add in MOBIL 1 Syn ATF?  I currently use MOBIL1 in the engine and I swear by the stuff. I hear nothing but horror stories about these trannies, and I want my baby to last alot longer than it has (over 185,000 km). 99 V6 SE (ATX)
Posts: 912 |
ford recommends mercon V transmission fluid in the atx.
at least mercon 3 though....you can get a case for like 15 bucks
Jason
00 Audi S4, 2.7 Bi-turbo quattro
01 S10 Xtreme, 4.3l
98' Contour SE with some mods
96 Cavalier (beater)
Posts: 28 |
WOW, Misinformation alert across the boards! I hear totaly different answers as to use Mercon, or Mercon V.... I'm just gonna check with the dealership around here, i'll let u guys know what i find out.
2000 Contour SE Sport V6 Duratech
Alpine MP3 CD Head unit
20% tint
AEM Short Ram Intake
Posts: 3,944 |
Why not just check out the new CD4E FAQ thread that I have started. One thing that I will need to add in there, is the fact that Ford did not start recommending MerconV for the CD4E until the 2001 or 2002 models came out. That would leave all Contours using only DexronIII/Mercon.
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Posts: 4,693 |
Ford still does not recommend using Mercon V in current production CD4E transmissions (as used in the Escape). They specifically state that Mercon V should not be used.
By the way, there is no such thing as Mercon III. The confusion may lie in the fact that any fluid that mets Ford Mercon specs also meets General Motors Dexron specs. The current level of Dexron is Dexron III. Prior to that, there was Dexron, Dexron II, and Dexron IIE.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 3,944 |
Originally posted by Big Jim: Ford still does not recommend using Mercon V in current production CD4E transmissions (as used in the Escape). They specifically state that Mercon V should not be used.
Jim, thanks for adding that bit of info. Oh yeah! Just so you'll know, I have a link to your Remote Trans Filter thread in the CD4E FAQ I started up there. Hince the reason I have taken it down. The other CD4E stickys will be coming down pretty soon as well.
Phillip Jackson
`98 Mystique LS
ATX rebuilt @ 151K
