Posts: 405 |
I was thinking of buying a cheap floor jack so that i could do more minor repairs at my garage. I was wondering if this was an ok one. http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00950181000 I'm mostly going on price and at 15 bux it's the cheapest one. although i don't want anything that'll drop the car.(especially one me) I also have jack stands to put the car on after i jacked it up. Just wondering if that one will lift the tour.
Tony Datsenko
Posts: 3,345 |
Yup, should be fine. Just make sure you use it on a level surface, because if you don't, it could roll on you.
1996 MM
Zetec, ATX
192000 kms...not dead, but I'm not fixing it
White people love Wayne Brady because he makes Bryant Gumbel look like Malcolm X.
Posts: 2,807 |
It will do fine to get the car up so you can use your jack stands. Never get under the car without using the jackstands.
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 21,653 |
Any jack is an OK jack. I use a $10 special from wal-mart. Always use jack stands no matter what. No new jack (unless something is horribly wrong) is just gonna drop the car. And hydraulic jacks usually slowly lower the car when they go bad, so even if you are using just the jack, you would notice it going down.
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 937 |
Originally posted by SVTCANUK: Never get under the car without using the jackstands.
And dont forget that parking brake
Former owner: 1999 Contour SE Sport
Current: 2000 Eclipse GT
There are three ways to do things: the right way, the wrong way, and the Max Power way!
Isn't that just the wrong way?
Yeah, but faster!
Posts: 5 |
This appears to be basically the same as the cheep Walmart Jacks. I actually would recomend you look for a long travel version of this jack. The one I have was something like $10 more than this one but it's lift range starts lower and finishes higher. That makes it much more versitile. I think mine is something like 4 1/2" to 17"
Posts: 2,426 |
Originally posted by nikkidanjo: This appears to be basically the same as the cheep Walmart Jacks. I actually would recomend you look for a long travel version of this jack. The one I have was something like $10 more than this one but it's lift range starts lower and finishes higher. That makes it much more versitile. I think mine is something like 4 1/2" to 17"
Make sure the lower and upper limits are good for you. I got a cheap one at Sears and had to go back and exchange it for a better one. The one I got the first time wouldn't go low enough for me to use.
Posts: 3,395 |
Originally posted by maxx_power76: Originally posted by SVTCANUK: Never get under the car without using the jackstands.
In my autos class.... teacher has us shift the car to N, and make sure parking brake is off, and then put some peices of wood around the opposite tire...
Posts: 937 |
In the 80's I was working on a car with a friend. we had the car jacked up with just the hydraulic floor jack. The jack blew an internal seal and that car slammed down to the floor fast. Nobody was under it, but I will never forget it!
99 Tropic Green SVT, Tan Leather, 20K miles, "Nice Twin" (factory stock).
99 Tropic Green SVT, Tan Leather, 28K miles, "Evil Twin" (Turbo AER 3L and more in progress)
96 Red LX, Opal Grey Leather 2.5L, ATX, 22K miles
Posts: 194 |
If you have a Checker, Kragen or Schucks in your area they have jack/jack stand sets for pretty reasonable prices. I got a set at my local Schucks, it's a bigger jack but at least it won't blow a seal like my little Sears one did.
Sarge43
"00" Tique 2.0L I4 ATX
"98" Mustang 3.8L V6 AT
The reason there's so much ignorance is that those who have it are so eager to share it.
