Posts: 50 |
What's this about Duratec, having been made by/alike Vtec, i was told that Duratec is like Vtec's little brother, does this engine have a special history behind it? I'd like to know more about this type of engine.
1995 Ford Countour SE
Kenwood Excelon Reciever
Polk Audio 6x9 speakers
'teal mobile'
Posts: 2,807 |
The Duratec was designed and built by Cosworth and Porsche. No relation to the Vtec that I know of.
99 CSVT Green/Tan
# 84 of 2760
15.376 @ 92.00 MPH Stock
75,000Km
96 Contour GL
2.5L V6 ATX 170,000Km
Posts: 661 |
VTEC only refers to Honda's twin stage variable valve timing system. (Not the whole engine) In the early years (1993-2000 or so) the cams only had 2 profiles so the VTEC "kick" would hit at high rpms.
Nowadays, they have iVTEC which is more variable, I think on both intake and exhaust cams and it is more or less infinitely variable over a range of camshaft overlap angles. Of course, it's not truly infinite, but much more so than before.
Duratec of course is the name given to the line of engines which include the 2.5, 3.0 V6 and now the 2.3 4-banger. I believe in Europe there are more 4-cylinders that wear the "Duratec HE" designation.
Ford used to say no tune ups required for 100k miles, but every manufacturer seemed to drop that claim in the late 90s.
Kerry
99 SVT Contour Silver Frost, #365/2760, DMD
98 Audi A4 2.8 Quattro Tiptronic, 30V -- SOLD!
91 Isuzu Impulse XS Kammback, Handling By Lotus
Victoria, BC, Canada
Posts: 536 |
If I ever hear someone say that My engine is the VTEC's lil' bro, I will do two things. Sell my car, and kill myself.
99' SVT #811 of 2760
Born on january, 12, 1999.
"This may have been his only shot at number one, but he just sucks on so many levels that I couldnā??t even let him win a contest of suckiness."
Posts: 7,100 |
Your engine is Vtec's li.... Nah... not going there. LOL  Ray
'99 CSVT - Silver #222/276
Posts: 5 |
The duratec has similar engine internal dimentions, the wrist pin diameter is the same, the piston CD is the same, the rod length is within a couple of thou, other than that nothing is honda about it. The engine that the 2.5,3.0l is like is the 4.6 cobra. The cam tentioners, lifters, followers, oil pump, valvesprings, retainers, valve locks are all the same, the way the engine is designed is nearly identical. So in reality the dura is the Cobra's lil bro.
Remember the process, not just the reaching of the goals... --LRD
Sponsors, AEM, Wilson Manifolds, AFCO, BEGi, H.O. Fibertrends
Posts: 7,100 |
AEMTuner, off topic... You have a PM...
Ray
Posts: 140 |
Honda has / had spys at Porsche engine development....
Posts: 9,602 |
Originally posted by Burk: What's this about Duratec, having been made by/alike Vtec, i was told that Duratec is like Vtec's little brother, does this engine have a special history behind it? I'd like to know more about this type of engine.
Go away troll...
Your ignorance is hardly worth noting except only to let you know it is a source of amusement for us because you can't be serious...
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 9,602 |
Originally posted by AEMtuner: The engine that the 2.5,3.0l is like is the 4.6 cobra. The cam tentioners, lifters, followers, oil pump, valvesprings, retainers, valve locks are all the same, the way the engine is designed is nearly identical. So in reality the dura is the Cobra's lil bro.
You also are not even remotely close to correct.
Folks if you have no clue PLEASE do not post because those of us that do are going to rip you apart quite completely.
2000 SVT #674
