#910325 03/26/04 12:51 PM
I have a 98.5 SVT with 30K miles on it. I did a search regarding the water pump issue, but did not get the exact answer I was looking for. My question is, does my car have the pump with the plastic or metal impeller? I read one post where somebody with a 98.5 had a metal impeller. Was the plastic impeller on the E0's only? If I do have the plastic impeller, should I begin to think about replacing it? Thanks in advance.
1998.5 CSVT 34,000 miles 2005 Volvo XC90 V8 1971 Duster 360, 3.55 POSI
The OEM is Plastic and the Metal impeller is avaiable. Aftermarket I cant remember the link.. I think my water pump gave out at 55-60 Thousand. Its been a while. I think it was SHO Shop that offered it.. cant remember, but I'll look it up again..
H
H
If yours is the bad one it wont fail till like 55-65k. So you have lots of time yet, and at the rate your going with miles on your car you may not need one for a while. The one you want to get to replace this one is the one with the metal impellear is at NAPA that is the best one there is.
Well, I'll be turning into my daily drive in a year or two, so the miles will begin to pile up. How do I know for sure if it has the plastic impeller? Did all of them come with a plastic impeller and the metal was only available aftermarket?
