This is my first post as a registered user, so I apologize if this is boring. I've been visiting this site almost daily for about a year now, and the maintenance tips I have found have almost entirely weaned me from the necessity of going to the dealership for basic stuff
A few questions...
1) The owner's manual for my '98 SE (V-6, ATX, 60000 miles) list MERCON power steering fluid, but my Haynes manual list Type F automatic transmission fluid. I am wanting to flush the original fluid out but do not know what to replace it with. From what I can tell, the original fluid is a darkening shade of red (AT fluid?), but new PS fluid appears to be clear with just a shade of yellow in it. Which one is correct?
2) I've done a search, but have not really found what I am looking for. I am wanting to flush and refill the PS fluid. I have seen the "turkey baster" method and others have suggested going somewhere to have it done. Is there a way for a DIY-guy to flush out the entire system? A couple of weeks ago, while I was changing the oil, I noticed a small cooler in front of the radiator and followed the lines and determined this was a PS fluid cooler (right?). Is it possible to detach one or both of these lines to drain the system or am I asking for trouble. My only concern is that air will get trapped in the rack-n-pinion when I refill. I understand the concept of 'bleeding' the PS... and if I do refill, what's the capacity?
Any tips would be greatly appreciated. The guys and girls on this forum have been a Godsend. Thank You.
1998 Contour SE, V-6, ATX, everything stock (70,000 miles on original ATX and water pump and counting)
H
H
Here ya go these are directions I created....
By the way you have to use Automatic Transmission Fluid Tpye "F" it is very important you get the correct fluid and use it otherwise you will most likely damage parts of your steering system.
Tools you need
- needle nose pliers/vice grip
- drain pan
- 5/8 hose clamp, screw type works best
- 3 quarts of Automatic Transmission Fluid type "F"
- duct tape
- funnel
- trash bag
- friend to help you
- towels
- Phillips screwdriver
Okay the first thing you need to do is set the drainpan under the car, you should set it about where the resivor is, then put the trash bag on the side of the car to prevent fluid from getting on your car. Secondly you need to remove the power steering resiovor cap. Using the vise grip pliers brake away the clamp that is attached to the power steering hose that runs parallel to the firewall, just go ahead and get the clamp off anyway possible. When you get the clamp off, you need to take the needle nose pliers, and force off the hose. When it comes off cover the white end from the resiovior where it came off with the duct tape.
Now set the funnel in the resiovor. Have your friend start the car but tell him not to turn the wheel, fluid will be draining out of it. After 20 seconds or so, have them shut it off. Okay get the fluid ready, have them start the car and turn the wheel gently, as they are doing this old fluid will be coming out of the hose so you need to pour new fluid in fast. If at any time you hear a groaning sound have them shut the car immediately, you wernt pouring fluid fast enough. With it off fill to the max line, then have them restart. You need it so they can turn the wheel to the left and right all the way without having any groaning sound. When they can do that, reconnect the hose, but first slide the clamp on it. Now tighten the clamp tight. Fill the resiovor a bit above the max, as it might drop a bit, mine did.
Keep an eye on the fluid for day or two.
Mobil 1 ATF & a complete system flush
How much fluid does the P/S system take?
How much is needed to flush?
CSVT Feels Like Heaven Goes Like Hell Profile
Type F fluid was specified in 95. Mercon after that. Mercon works just fine even in a 95.
Mobil 1 ATF is a fully synthetic Mercon spec fluid and also works fine.
Valvoline Synpower power steering fluid is specifically a power steering fluid and not a trans fluid that also works in power steering systems. It works fine as well.
H
H
Obviously you didnt read my first post to good.
" 3 quarts of Automatic Transmission Fluid type "F"" it says that in the parts list.
Type F is not specified by Ford for the Contour on the newer models. I'm not positive when it changed, but I think it was 1996. If it really matters to you I'll check the Ford shop manual. I know for absolutely certain that Mercon is specified for my 98. It is in the owner's manual.
I just found it in the 1996 Contour shop manual and you will find it at the bottom of the specification page below.
Also there was no change in the hardware between the 95 and 96, just a change in spec for the fluid. I have used Mercon in power steering systems that specified type F for years with no ill effects.
I'm sorry that my experience is different from yours.
Section 11-00: Steering Systemâ??Service 1996 Contour, Mystique Workshop Manual
SPECIFICATIONS
SPECIFICATIONS
STATIC STEERING WHEEL TURNING EFFORT Vehicle Power
Contour, Mystique 31-35 N (7-8 Lbs)
POWER STEERING PUMP SPECIFICATIONS Engine Minimum Flow a @ 5100 kPa (740 psi) Maximum Free Flow @ 1500 rpm Pump Model
Liters/ Minute 78°C Gallons/ Minute 172°F Liters/ Minute Gallons/ Minute
2.0L 3.4 0.9 9.8 2.6 HBD-AE
2.5L 4.7 1.25 9.8 2.6 HBD-AE
a Flow depends on power steering pump model, engine rpm and pulley drive ratio. Engine idle rpm must be set to specification when checking power steering pump minimum flow capacity.
POWER STEERING GEAR OPERATIONAL SPECIFICATIONS Description Specification
Number of Turns 2.75
Power Steering Fluid Capacity (Including Steering Pump) 1.18 Liters (2.5 Pints)
Tie Rod Articulation Effort (On Pull Scale) 5 kg (10 Lbs) Maximum
No Free Play Permitted
Tie Rod Outer End Lubricant None
POWER STEERING RELIEF PRESSURE Engine Minimum Relief Pressure Max. Relief Pressure
kPa psi kPa psi
2.0L 7240 1050 8480 1230
2.5L 7240 1050 9510 1380
LUBRICANT/ADHESIVE/CLEANER SPECIFICATIONS Description Part Number Ford Specification
Premium Power Steering Fluid E6AZ-19582-AA ESW-M2C33-F
Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid â?? MERCON®
Thanks, Big Jim
I just love these coy statements.......Big Jim did you pick that up at the office???
Regards,
Bob
Type F fluid, is an obsolete ATF and is more slippery than Mercon/Dexron. It has no friction modifiers that give Mercon more "bite" to the clutches.
Since the later Contours use Mercon I would say you would not have any problems in your car.
I use Synpower PS fluid in my 96 which requires type F and have seen no ill effects.
I also use Lubeguard PS fuid additive, which is purported to be quite good - look at their website to find more info.
Dan B. 96 SE 2.5 auto
