I have a '95 Contour SE w/ manual transmition
I first noticed that the throttle was sticking on the highway. I was on a trip and had been using cruise a lot. I thought cruise was on but when I clicked off nothing happened. I tried hitting the brake peddle, but the gas peddal wouldn't come out. I put in the clutch for a second and imediately the engine started to rev up, so I left it in fifth (manual). I shut off the car, and started it(on the highway) and , but the gas pedal wouldn't come out. Eventually I sut off the car, pumped the gas a few times, and restarted - and it freed up a little.
I made it to a gas station and checked out the cables. I don't think it has anything to do with the cruise. I just cleaned the TB, so I know that's not gummed up. I think it could be three things:
1) Cable from peddal to traction control module,
2) Cable from traction control module to tb,
3) or traction control module.
has anyone had a problem with these? Any suggestions as to what I should check out/replace?
P.s. It was snowing/freezing rain on the trip. I wonder if water could have got in and froze up lines (while on highway)
Thanks,
Nathan
