#906036 03/21/04 11:10 PM
Just figured I'd run this by everyone, so in case something is missing I can go run out and get it.
Basically is anything missing, or recommended to change while I am doing this.
Being installed:
-New MTX75: Modded (listed in my sig)
-Spec Stage 1 Clutch
-Spec Flywheel
-New rear trans mount (urethane filled)
-Trans Fluid
-Gaskets
-etc...
Does the Spec clutch kit come with everything needed?
Is there anything else I need for the install, or I should install?
I using my friends shop on Friday to do this, he's done other cougar/contours, so we should have this all done in one day. Actually he said 5 hrs...I removed my subframe like 2 months ago, cause I was having alignment issues and the Subframe looked as if it may be screwed...We found out it was a faulty strut, which was replaced, but wanted to check out everything. So the subframe should come off in a snap.
Well hopefuly this trans performs like I calculated it to. Should be fun.
Thanks guys...
99 Cougar V6 MTX...Plenty of mods My best mod thus far: Trans: Brand New MTX-75 with B1 gear set, Quaife LSD, 4.5 Final Drive, Spec Stage 1 Clutch, Spec Aluminum Flywheel...
Does this mean I'm good to go?
I just like to make sure I got it all. I never like forgetting anything, and I likt doing everything at once.
Thanks again...
