Coors Offline OP
I received this from member wjang today. It is a nice diagram for the wiring colors of the premium sound system. This one is for a cassette system, but the CD one is the same. There have been a lot of questions on bypassing the amp and what wires go where and do I need a harness. Well with this you can just match up the wires and forget the harness if you desire. At least it should help with bypassing the amp since people have had trouble getting the right adapter to hook up to the speaker wires. Just slice 'em and splice 'em.
Thanks again for the diagram Wes.
[This message has been edited by Coors (edited February 24, 2001).]
Chad
http://www.1dzine.com
jetski@mindless.com
98.5 SVT ? KKM Tru Rev ? Glasspack instead of resonator ? Dyno Max Super Turbo Muffler w/Brospeed 3.5" Rolled tips ? Brembo/KVR Cross Drilled Cadnium Front Rotors and KVR Carbon Brake Pads ? Blown Engine Replaced @ 41K
SOrry,
Can't see the picture.
Please send it to me via e-mail if possible.
Sadeeq@home.com
Thanks,
Sadeeq
Black is beautiful.
'99 Contour SVT.
Black '99 Contour SVT.
Stereo Upgrades & Cosmetic Enhancements
...Always clean, Always mean.
GNM Offline
The pic doesn't work. If you right click on it and go to Properties and copy the link and paste it into the link bar, then it should work.
Greg Mitchels
grdmasterg2@yahoo.com
Looking for an SVT! Wanna donate one?
[This message has been edited by GNM (edited February 24, 2001).]
Coors Offline OP
Posted new pic, and changed online server. The geocities thing is just not working out.
Chad
jetski@mindless.com
So I can bypass the amp? Do I just not plug in the harness but instead cut the wires and attach them directly to the speaker wires off the new head unit?
If that;s the case than the brown/red wire off the car splices onto the gray wire on the HU.
The white/red wire splices onto the gray/black wire. That's for the Right Front and that's me assuming that brown/red is positive an white/red is negative.
Sorry for all these questions, but I just got this 98 SVT, did one helluva burnout and the factory CD player died. Radio worked though, but I decided it was time for it to go. now I got a tape deck and CD Changer , but for the last 4 days I've just had an open space under the climate controls.
Someone please help me out. I'm struggling.
Coors Offline OP
yes, if you have an aftermarket HU, bypass the amp. The little things just dosen't have much power.
Chad
jetski@mindless.com
W
W
Glad the diagram is useful for some of you.
The info contained in the diagram came from a Haynes manual and my own car.
Just for a little clarification, the WHT (White) wire going from the factory HU to the factory amplifier carries the signal to turn the amp on (I have not checked this myself since I replaced everything).
I'm not sure what the "Door Lock Module" connection is for.
The color codes that Ford uses for the speaker connections will probably not match those of most head units, so here are the standard EIA codes:
12 Volt Switched (Ignition)...RED
12 Volt Battery (Always on)...YELLOW
Ground........................BLACK
Power Antenna.................BLUE
Amp Turn-On...................BLUE/WHITE
Illumination (Dash Lamps).....ORANGE
Dimmer........................ORANGE/WHITE
Speaker Connections
+ Right Front.................GRAY
- Right Front.................GRAY/BLACK
+ Left Front..................WHITE
- Left Front..................WHITE/BLACK
+ Right Rear..................VIOLET
- Right Rear..................VIOLET/BLACK
+ Left Rear...................GREEN
- Left Rear...................GREEN/BLACK
-Wes
98 SE Sport
F
F
Wes,
Do the Contours have the little flashing warning light to show that the PATS system is active in the head unit ?
On the Mondeos this light is incorporated in the dash clock and sure enough I have a Bk/Og wire going into that from the Door Lock Module.
Just a thought
Regards
Shawn
Coors Offline OP
Shawn yes they do have the flashing light and you are probably right on the money.
Chad
jetski@mindless.com
V
V
[QUOTE]Originally posted by Flipper:
[B] Wes,
Whoa whoa whoa.....so that means i could hook the alarm system that is from PATS to the radio??????????????
98 SE Contour
GTS Black headlight covers
300W X 2 Boss See-Thru Amp
2 350W MTX Terminator
Xeon lights
Coming Soon
16" American Racing wheels
skirt
mesh grille
K & N Air Filter
KKN Hood Kit
Moderated by  dnewma04_dup1
