#900493 03/15/04 05:38 AM
9
I know it's illegal to roll back on an odometer if it's the original... but say you buy a cluster from a car with different miles because you want a tach. Is it legal to set the odometer on the new cluster to the old cluster's mileage?
God graced us with intelligence, let's use it.
#900494 03/15/04 05:52 AM
why does it matter? as long as you put back the ssame milage no one is gonna know
1994 Volvo 850 Turbo 1992 Bronco Eddie Bauer 5.8 E4OD 1998 Contour GL 2.5 CD4E 2001 Montero Sport Limited 3.5 Auto 2002 IS300 3.0 Auto See My Cars
#900495 03/15/04 12:25 PM
H
H
I though if you tried to adjust mileage it brakes them things.
#900496 03/15/04 02:49 PM
nope, i bought a used svt cluster from a totalled svt. Only had about 3000 miles on it. If you take off the backing of the odometer you can adjust the mileage. Mine has worked fine ever since I adjusted it.
#900497 03/15/04 04:53 PM
you can very easily migrate your old odometer unit into the new cluster. it's in a rectangular plasic case held by 4 plastic screws on the backside of the speedo.
you have to pull the speedo needle in order to take the unit apart - do this gently using a fork or something like that as a lever. also, be gentle when pushing the needle back, don't push it deeper than it was.
will take you less than 10 minutes once you have the two clusters on the table in front of you.
Tiv
