Posts: 22 |
OK, so I just replaced my fog lights two weeks ago, with the silverstar halogen lights(not real HID's) and now one of them is alreay burned out. why is this. Also, I replaced and Upgraded the low beams too, and now they are shining too high, so i can't see in the snow. I adjusted them af far DOWN as they will go, but they're still to high. what's wrong with my headlights?
98.5 CSVT 5% in back 35% in Front
T-Red.Playstation 2. 5 1/2in tv.15in. Rockford Power series T1.Digital Audio 900 Watt amp. Pioneer Premier CD deck.New Trans and Engine 60,000 ago. For sale 8,000 O.B.O
Posts: 288 |
I've had the same trouble with the fog lights , the passenger side keeped burning out # 893 I believe. so this weekend I removed the splash pan cover under the car and removed both fog light housings. The lower screw bolt is a [censored] to get at I had to use a 7mm wrench to get it out. I put a teaspoon of dish washer deturgent in each and filled with very hot water, not boiling ,nevertheless very hot. Let them sit for a good 30 minuites. After ,I rinsed them both out. The film that had built up on the inside was remove and made them look like new. I replaced both foglights # 885 its a 50 watt bulb I got at Pepeboys then put the foglight housing back in and replaced the cover I put the metal speed nuts on the housing where the hole was instead of back on the bumper it made installation a lot easier.
As far as the headlights go check on the fitment of the bulbs in the housing its easy to put them in crook'ed try loosing the alignment screw up and that should level them out. Also a lot of aftermarked bulbs suck. Only oem replacments , piaa, katz, and razzo bulbs work best to my knowledge.
--- Maxx 2000 silver bullitt svt
-2000 csvt silver frost #1619
-magnaflow 14415
-optimized T/B & y-pipe
-superchips xgt1
-75mm proflow maf
-K&N RU-3530
-fsvt smart pump # 354Z-9H307-BC
-spec stage one, LSD
-low-tek,a/f,oil press.,volts
-B&M short shifter
-17" konig gt-r
Posts: 92 |
Our cars have a bad habit of cracking the top of the lens where it meets the fog light housing. Ford recycled the design from the Probe fogs. I went through 6 bulbs before figuring that one out. You may have to replace your fog lights...
If less is more, think how much more, more is...
Posts: 1,049 |
im going to replace my fogligth with projector style foglights im gonan try to mount them to the factory fog bracket an dif not ill just moth them somewhere els. like in the mouth of the bumper onto the metal bumper bar. plus teh stock fog lights have a horrible lens and weak reflector.
