Why: R-134a (refrigerant) leaked out - Find the leak Overcharged with refrigerant undercharged with refrigerant Bad A/C Compressor Clutch Bad A/C compressor Bad high pressure switch Bad low pressure switch Fuse blown (Cabin)Fan switch broken Condenser Fan thermostat broken Condenser fan broken wire loose wire broken heat/cold selector broken Vacuum leak in Heater / A/C module Damper actuactor broken Damper Actuator disconnected Serpentine belt missing Serpentine belt broken The Car doesn't have A/C and the owner didn't know it
These are not in any particular order.
I might of missed one or two, but it is probably one of these issues.
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
