#72617 02/14/01 09:45 AM
Jazzman Offline OP
Will all aftermarket HUs be compatible with power antennae? Can anyone let me know if they've had any success stories/horrible failures? Thanks!
Brian
1998 Mystique LS V6 ATX
Satin Green/Grey Leather
Moonroof
Ford Remote Starting System
885s for fogs
1998 Mystique LS V6 ATX - Satin Green/Grey Leather
Moonroof - Ford Remote Starting System
885s for fogs - Fogs with Parks
JVC KD-SH99 MP3 - Pioneer TS-A6865s in the doors
JVC 12-Disc Changer
"Sometimes I'm good, but when I'm bad, I'm even better."
The three HUs I've had in my car all seemed to work seamlessly the power antenna. I have had one Blau and two Sony's.
Jazzman Offline OP
Is the Power Antenna hook-up part of the wiring harness? or is there a separate harness needed? If it's plug and play, great.
JVC 12-Disc Changer
It's part of the harness...just plug and play!
Brian
Most aftermarket head units come both with an amp remote turn on (blue/white) and a power antenna turn on (blue). If you have the premium sound system than you need to use both of these wires since you have an amp and power antenna. If you were to switch these wires you would find that when you put in a cd there's no music and your antenna goes up. Just make sure you go to your local shop and pick up a wiring harness (metra 99-5511) for premium sound and no premium sound (metra 99-1770). And just match colors together from the radio harness to the metra or other OEM wiring intergration harness.
[This message has been edited by T.J. Fontana (edited February 14, 2001).]
Moderated by  dnewma04_dup1
