Posts: 8 |
Just wonderin if there are any Svt's or Se's running around out there with twin turbos spooling under the hood? If so what'cha got, who helped you, and how much horsies you pushing now?
'98 SVT
polished MAF
K&N Filter
Soon to be ported and polished heads
"Absolut Rara."
"Absolut Rara."
Posts: 3,223 |
No, no one ever has, and in the case of the contour, a twin setup is no better than a single turbo.
Posts: 7,025 |
nick, a single turbo is already crammed enough underneath the hood of our car. Fitting a seperate collector pipe, turbo, wastegate, and downpipe is just down right ludicrous. I dont even think there would be enough room for a intercooler after all that. theres not enough room, not to mention, as rara said, there are no horsepower benefits from a twin turbo setup vs a single turbo kit on the duratec.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 610 |
Originally posted by beyondloadedSE: there are no horsepower benefits from a twin turbo setup vs a single turbo kit on the duratec.
Theres no proof of that being true. I would really like to try.
2001 BMW 325i Sport, Stickshift
'96 Mercury Mystique V6 *TOTALLED*
For sale:
Alpine CDA-9811
Eclipse Amplifier
Pioneer Tweeters
Posts: 7,025 |
come over and check out the engine bay of my car....youll see what im talking about.
Jim Hahn
Posts: 495 |
You won't see more HP cause the stock block will only do so much either way, but you MIGHT see quicker spool up, but we're talking full boost by 2500rpms vs 2800, assuming you could squease'em under the hood anyway. And yeah, twins might not be better than a single setup, but twin turbo's are cooler.
2000 Rio Red I4 Cougar
200whp & 210wtq at 9psi
254whp & 276wtq with NX 35shot
WRX TD04 Turbo, Cut Short Shifter, Strut Tower Bar, 17" ZN Wheels, Roush Springs, Starion Intercooler, NX 35 shot, HKS SS BOV, Full 3" exhaust,StreetFlight Chip
Posts: 1,695 |
The only real benefits to using twin turbos are spool time (yeah.. not the best term.. so sue me). Twin turbos or a single turbo forcing the same amount of air into the engine would make the same hp.
04 Subaru WRX "Eurosport bling bling fast and furious tokyo drift"
"They have diarrhea of the mouth, and constipation of thought"
Posts: 9,065 |
Originally posted by beyondloadedSE: nick, a single turbo is already crammed enough underneath the hood of our car. Fitting a seperate collector pipe, turbo, wastegate, and downpipe is just down right ludicrous. I dont even think there would be enough room for a intercooler after all that. theres not enough room, not to mention, as rara said, there are no horsepower benefits from a twin turbo setup vs a single turbo kit on the duratec.
Only case, Noble M12...
Posts: 3,045 |
to solve this question we should look at the enemy (ricers) who admittedly have more hard knocks here than we have. guys running twin turbo supra's and rx7's routinely pull there twin setup and replace it with a decent sized single turbo. advantages: lower cost, less room needed, less complicated, less weight. an example is garretts line of gt series turbos with a dual ball bearing center section. this allows a medium size turbo to spool much faster than it would five years ago. any body running a turbo in our car who doesn't want to waste his tires at every launch should consider a multistage boost controller. i've seen some in turbo magazine that allow you to program a minimum boost level at initially and increase it as rpm's rise or i think (not sure here) after you leave first.
00 black/tan svt, #2052 of 2150, born 2/1/00
formerly known as my csvt
"Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
Posts: 2,353 |
Originally posted by MapOfTaziFoSho: Originally posted by beyondloadedSE: nick, a single turbo is already crammed enough underneath the hood of our car. Fitting a seperate collector pipe, turbo, wastegate, and downpipe is just down right ludicrous. I dont even think there would be enough room for a intercooler after all that. theres not enough room, not to mention, as rara said, there are no horsepower benefits from a twin turbo setup vs a single turbo kit on the duratec.
And Duttweiler(sp?) IIRC
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
