#896985 03/11/04 03:45 AM
My mom's fuel pump went out in her Mystique today. I plan to tow it home and change it myself, but I have a question: In the Haynes manual, it says there is an access plate in the floor, underneath the rear seat. Get to that, and you can change the pump without pulling the tank. Is this true? More to the point: is this true of '98- '00s?
Black/tan early '98 Contour SE Sport; dead-dead-deadsky (gone, split, outta here, afterlife kids) '05 Pontiac Sunfire; 2.2L Ecotec, ATX, well-equipped Mom also has black/tan '98 Mystique LS; V6, ATX, Alpine CD deck
#896986 03/11/04 03:51 AM
I know if you lift the back seat up, the fuel pump is there, at least its that way on my 95 Tour
Former owner of a 1995 Ford Contour GL w/ 2.0L ATX Proud owner of a 2005 Ford Taurus SE 3.0L V6 Vulcan --Looking for Commodore stuff (Drives, Units, Amiga, games, etc)If anyone has any of this laying around and wants it gone, lemme know --
#896987 03/11/04 05:44 AM
If you have a late 99 or 00 Contique with the returnless fuel system, it is a little harder. The hole in the floor did not get any bigger, but the fuel pump did. You must open the hole in the floor a bit bigger or you must drop the fuel tank for access. Even if you don't have the returnless system, you may learn something from this FAQ.
http://www.contour.org/mods/mods.php?s=howto&displayid=39
#896988 03/12/04 02:23 AM
Also, it is a big PITA to turn the lock ring off. Be patient, work steadily. I used a hammer and brass drift and slowly, ever so slowly, with light taps, managed to get it off. I tapped lightly all the way around on the raised portion of the ring. You'll see what I mean when you remove the cap under the seat. Don't get too muscular with it.
Aloso, the seat can be a little tricky to pick up and you may break the plastic clip that holds it in. Mine was already broken by the alarm installer. I didn't know until I went to repair my pump.
Also, get a new o-ring for the access hole. The original one will br stretched and won't fit back in. The O-Ring on mine was green colored, if it matters. I repaired mine but you have to know how to do this. WE have o-ring repair kits at work. I recommend a new o-ring.
My name is Richard. I was a Contouraholic. NOW: '02 Mazda B3000 Dual Sport, Black BEFORE: '99 Contour SE Sport Duratec ATX Spruce Green PIAA 510's, Foglight MOD, K&N Drop-in
#896989 03/12/04 03:15 PM
Mission accomplished! I dug into it yesterday, and it took me all of thirty minutes to change it out! And to think Reynolds Ford in East Moline wanted $250 for labor alone. That translates into $500/hour. And they know about pulling it from the top, too.
#896990 03/12/04 06:19 PM
Congrats!
It is WONDERFUL to hear of a DIY triumphing over the evil forces of the $500/hr dealership ripoff!
1995 Contour GL "GEX" 2.0 Liter 4-banger ATX 162,500 miles Stock except for two '89 Tempo wheel covers & two VERY COOL cosmic looking '76 Toyota Corona wheel cover Full size spare No rust Green Purchase price: $500
#896991 03/12/04 09:01 PM
1
i had to replace my fuel pump in my 99 tour. The hole under the seat was to small so i had to drop the tank. Worst job ever. Everything was in the way. I finally got it out and fixed it and now i have another problem. When i fill my tank up with gas it leaks out the filler neck hole on the gas tank. I dont understand because i completely wiped the seal and the hole in the tank completely clean. Any ideas?
#896992 03/13/04 01:12 AM
F
F
You may have to bite the bullit and drop the tank again to get it on correctly.
96 Sport 2.0L - 190,XXX miles
#896993 03/13/04 03:22 AM
hope you didnt brake that white round clip on the filler pip cause if ya did you have to buy the whole filler pipe
1999 Ford Contour SE Zetec with 137k miles. AIM Name: ContourAlf Yahoo IM: Contour_Freak
#896994 03/13/04 04:32 AM
If you ever need to do the pump again, just cut the sheet metal under the seat. I cut 4 lines (radial) and bent up the metal. Bent it back down when finished and used duct tape to seal it.
