#893071 03/07/04 09:20 PM
'oo svt with 47,000 doesn't seem to pull strong past 4000rpm so purchased the focus pump that was recommended here on CEG... NOT a direct swap!! the housing, wiring and fuel line were all different connectors! I operated though and took out the actual electronic pump and put in my old housing but car is still behaving the same way!!??
any ideas?
'00 SVT 49,000 Silver Frost b&m short shift, 17"tires, driver 100mph+daily
#893072 03/07/04 09:42 PM
Clogged disc filter on the pump housing, fuel filter, secondaries not opening.
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
#893073 03/08/04 03:47 AM
demon... do you know why the pump doesn't fit?
#893074 03/08/04 03:52 AM
wow im dissapointed.. i remember reading that the pump was a direct swap.. why didnt it work for this guy? not cool.... as far as your question i bet its your secondaries dude.. check em out... maybe a snapped cable or they're just clogged... change the fuel filter too.. its at easy thing to do
Lexus ES300
#893075 03/08/04 05:18 AM
i have changed the fuel filter, plugs, cleaned the maf, etc... car does pull strong when first started but after driving a little then loses the pull.
#893076 03/08/04 12:36 PM
Did you take the disc filter off of the pump housing?
#893077 03/08/04 03:22 PM
yes, also removed the disc on the bottom of the filter... the new filter doesnt even have a place for that.
