#892829 03/07/04 10:37 AM
and it ROCKS!!! the contour sounds SO good with the new set up! i just replaced the headunit with my old kenwood, EQ and changer with a 500W amp with a 12" sub and the car BOOOOMS like crazy!
i kept the stock speakers and to my surprise, they are not bad at all!! the only bad thing about my set up is that the EQ looks totally outta place cuz thers no place to mount the darn thing besides for the space underneith the headunit... and thats not a good place cuz the EQ totally stick out like a sore thumb... another bad thing is that im getting a slight feedback noise but its not very noticeable since i have th volume cranked up pretty good most of the time~ i guess the next thing is to find a location for the EQ... i gotta fix that soreness...
2000 Silver SVT Contour - Daily Driver 1996 BBB Impala SS - Garage Queen http://www.cardomain.com/id/ghosstryda
This is a shot in the dark, but about the slight feedback noise, did you bypass your factory amp?
Also make sure you have a good ground for your Amp. Make sure you sanded off any paint, and make sure that the ground to your battery is in good shape as well.
Jonathan '96 Contour Zetec MTX 208,XXX miles
batmobile~ i dont think so! good point, im gonna take it back next weekend and have them take it out.. its located behind the glove box right??
BlackSativa~ i believe the ground from the amp and battery are done right, it looks like a clean job.
thanks for the suggestions guys!
Moderated by  dnewma04_dup1
