Ok, so i'm a little concerned about the oil pressure. When first starting the car it hovers around 75psi until the engine warms up about 15 mins later or so, then it will hover around 30psi at idle. when cruising down the road, it again hovers around 75psi until you slow down or come to a stop. any slight blip of the throttle and it jumps to around 75psi again. Main question, is it normal to be so high for so long at start up until the oil gets hot??? I mean to tell ya, when I first start er' up and it just shoots up that high, was kind of a scare at first. Just wondering what everyone else is experiencing that has an oil press gauge installed. btw, my sensor is tapped into the back of the engine block where the factory oil press unit is located... Ok, open floor, discuss....
