Simple diagnostic:
Rotate your tires front to rear.
If the noise moves to the rear, it's a tire.
If it stays in the front AND the pitch of the noise is directly proportional to you ground speed, it is a wheel bearing.
If it is proportionate to the engine RPM, then it is most likely an engine accessory or the engine and should be audible when the car is not in motion.
Steve
