Page 2 of 2 1 2
These are my old wheels, they are the superior scoundrels.
Make sure you don't get any money for them svt37, after all I didn't.
SVT with CE light mod and a camera mount. Naughty Pictures Why yes it is true, I am on my third engine.
That is what I thought. Svt37 check your pm's.
1999 Blk/Tan CSVT #654 - SOLD 2003 Suzuki SV650s
Hey guys....im mpicking them up tonight...bringin NORCALCOUG with me to check them out to make sure there ok...we agreed on an trade only...no money will be exchanged.
Lupe
#889632 03/07/04 04:05 AM
Problem.....OK we switch rims...Left for left and right for right.
Well i had them balanced today.....they were going in the wrong rotation!!!!!!!! So Firestone had to switch the side of the rims so the tires would rotate correctly.
Well before all that, with the new 17's on the car, the car at down shifts and hard acelleration would pull to the right.
Now since they switched the rims to the correct sides it now pulls to the left!!!!!!!!!!
What the hells up...there was no inperfections that we could phisically see on the rim and no visible damage.
On top of that, Firestone found the serial numbers on the tires had been removed....which leads me to believe that the tires were either used or "HOT"!!!!!
Anyways, what should i do about the "PULL"....and i had an alignment about 3 weeks ago??
Lupe
sounds like one tire is bigger then the other or the tire presure is different between the two,i would check the presure and make sure both tires are the same size.
this might be a case were one tire has more mileage then the other tire.
98 svt sil/blu 3.0 oval heads full P&P, msds headers,bat kit,2,1/2exhaust 30 inch glasspack and 2 spintech mufflers 14.78@94mph with my mechanical arm i can shift gears in less then a twentieth of a second for sale $7000
Lowbudget...you are correct....turns out the left side(both front and rear) have visably less tread than the right side....looks like i need to get new tires.....thanks for the heads up...im not that familar with tires.
Lupe
thats why they pay me the big bucks!
Page 2 of 2 1 2
Moderated by  Fmr12B_dup1, path914
