#887775 03/02/04 01:27 AM
lucky13 Offline OP
What sort of issues do I have to look forward to as far as the fuel system in concerned? Also, anybody know a ballpark figure on replacing a roller rocker arm?
98 CSVT black/midnight Trubendz catback, BAT inlet pipe, 75mm Pro-Flow, K&N open air on SCA cold air pipe, Optima Red Top in trunk, short shifter, Richbrook e-brake, lowered, side markers, mesh grille/bumper inserts
#887776 03/02/04 01:26 PM
Learned patience the hard way
Shouldn't have any issues as long as it has a return system on it. Even if it doesn't, just swap your old fuel system onto it. The roller rocker is a bit of a pain. You've got to pull the valve covers and loosen the cam up that is on it to pull it out. Probably looking at 4+ hours labor at a minimum. Part is very cheap compared to the labor.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180 Buckshot77@msn.com Misc 3L parts for sale
