#886269 02/29/04 07:30 PM
H
H
My '95 Contour 2.0L auto just began to run terrible and making some serious noises from the motor. I checked the timing belt for tension and it seems loose, and I'm guessing the belt jumped timing on the camshafts. Now it will turn over but no start. Is this motor a non-interference type, or should I expect valvetrain damage? Also, any tips on changing the belt would be helpful!!!
thanks,
tj
#886270 02/29/04 07:39 PM
H
H
Yes, you can expect major engine damage because the engine vavles hit the cylinders I think is what happens. Anyways ( at least)one guy had that happen on here and it cost him $1800 to get fixed.
Suppoused to replace it every 75,000 miles.
#886271 02/29/04 10:18 PM
The Zetec is supposed to be a non-interference engine, that is if the belt breaks then the engine just stops...no harm done. But if the belt jumped a cog or two the valves may have been operating at the wrong time...you won't know for sure until it's checked out.
- Jim Our yardbirds: Belvedere, our '96 Jeep Cherokee, 4.0L ATX, 85,000 and going strong Spencer, our '03 Chrysler PT Crusier, 2.4L ATX, 28,000 and just getting started
#886272 03/01/04 03:35 AM
on a non interferrence engine the valve and head will not meet...
#886273 03/01/04 04:41 AM
Yeah, that makes sense...
#886274 03/01/04 10:58 PM
H
H
With the crank at #1 TDC, how are the camshafts oriented to put it in proper timing?
#886275 03/02/04 12:00 AM
H
H
Yes #1 cylinder must be TDC and you have to have a crankshaft/camshaft alignment tool to do it correctly.
#886276 03/07/04 09:56 PM
If you tried to do the belt yourself, you probably had a problem with cam gear alignment and proper tension, unless you had the right tools [set of three...seems like I spent over $300.00]. I've seen a few where the right tools weren't used = rough idle and lots of noise.
#886277 03/07/04 10:41 PM
well someone got ripped off... you would pay alot less for a full zetec swap.. with an engine from a salvage yeard.
Lexus ES300
#886278 03/08/04 02:26 PM
In the Haynes manual, it shows a picture of the tool to use for cam alignment. Funny, it looks like a peice of angle aluminum to me, so that's what I used. To take up the slop because the angle was a little undersized, I added plastic shim stock to make up the .030 or so difference. Worked great, cost me nothing.
Britt Boyette Break Like the Wind Racing
