Posts: 4,970 |
Originally posted by Rev. Po-Jay: I could tell the car that it is a monkey, if I wanted.
IIRC, War. already did something close to that Raped ape mode.......is that an e-manage only setting?
2005 Ford F150 SuperCab FX4
1964 Chevrolet Impala SS
Posts: 13 |
Originally posted by incubusjunkie614: Originally posted by Rev. Po-Jay: The beauty is that you "could" run catless without throwing a code, if you tuned a chip correctly. [Lawabidingcitizen]Not that anyone would run catless[\Lawabidingcitizen]. Most states just tap into the computer and whatever it says goes. I could tell the car that it is a monkey, if I wanted.
lololololol that would be quite a site to see.... maybe we all should just register our cars in wisconsin or michigan, no emissions
What do you mean no emissions? I have to get my Contour checked at least once every two years. Are you saying they wouldn't check for the precat being removed? I sure hope so because want the turbo for SCCA racing and would have to drive the car to the races. If this would be problem, someone with ODBII knowledge please tell me how to "program" the control module so it reports A OK! Please...
Dan
Posts: 4,970 |
Chris (Keyser) can help you with that Q. PM him
Posts: 13 |
This would not pass emissions check running catless. Right?
Posts: 13 |
don't forget about Florida, they don't test anything down here...
Are you sure about this? Because if so I think I could have my car registered in FL because my parents have a condo there. Florida plates but the car would be kept in WI. Doable?
Posts: 1,346 |
Originally posted by DanS: Originally posted by crusinmercury: Originally posted by incubusjunkie614:
DO IT!!!
E1 CSVT
s/c-----x
turbo---x
3L------check
Posts: 3,045 |
in ca they will check everything and fail you if they do not see something even if you pass the sniffer with flying colors. some people here have been know to gut the cats to solve the problem. but then you must make sure you tune it right. if it is done right, your car will look like it has precats, and smell like it has precats without actually having any. additionally any after market parts you put on your car (in cali) that even remotely deal with emisions must be c.a.r.b. certified or you don't pass. basically the epa is strangling cali.
00 black/tan svt, #2052 of 2150, born 2/1/00
formerly known as my csvt
"Nothing in the world is more dangerous than a sincere ignorance and conscientious stupidity." -Martin Luther King, Jr.
Posts: 2,353 |
Here in Cali, you really have to find a side-street smog place and do a hint, hint, wink, wink kinda thing. Always worked for me in the past for visual inspections. Of course, this is assuming you can still pass the actual emissions portion of the test, otherwise you're screwed.
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 449 |
I can't figure out why the geovernment cares about visual as long the emissions are clean ??
98.5 SVT now gone ... new wheels = 2005 330i
