#885708 02/28/04 11:33 PM
F
F
tried pulling all of the fuses under the hood and under the driver-side dash, and replaced bulbs .. to no avail..
what can i be missing?
#885709 02/29/04 12:34 AM
Do you mean the lights for your license plate? If so, did you clean the connectors when you replaced the bulbs? I did that and I haven't had any problems since.
1996 MM Zetec, ATX 192000 kms...not dead, but I'm not fixing it White people love Wayne Brady because he makes Bryant Gumbel look like Malcolm X.
#885710 02/29/04 01:11 AM
F
F
yeah i just tried cleaning the connectors, that didnt help
#885711 02/29/04 08:21 PM
F
F
up
#885712 02/29/04 09:59 PM
Have you traced the wires back from the connectors to see if there are any breaks in them? At the same time I replaced mine, I had to replace the wires because they were so corroded.
#885713 03/02/04 12:52 AM
F
F
yep, i tried all the connectors, and the contacts all had some sort of grease in them, i guess that kept the rust off, but none of the wires appeared damaged, or cracked at all.. i traced the wires from the bulbs back into the rear deck, and thats just about as far as could get..
does anyone know exactly which fuse runds the tag light?
and is it under the hood or under the dash?
thanks
#885714 03/02/04 03:24 AM
F
F
unbelievable
