Posts: 14 |
Hello, I am a n0ob here on the countour.org forum.
I am helping a buddy of mine out with his 98 contour, with ATX. He just had a rebuild, and I am wondering if the contour has a stock transmission cooler, and if anyone here has an aftermarket one installed.
Also, I see some of you have aftermarket remote tranny filters installed. Won't they cause pressure drops in the line?
Thanks -D. Carlsson
Not really a contour guy, but a few friends have them so I help them out. Im a Moderator at taurusclub.com
Posts: 429 |
The stock cooler for just about every car made is a coil inside the radiator coolant return tank. While probably OK for the average motorist, it is probably inadequate for performance applications, trailer towing and hot weather climates such as Arizona, Florida, etc.
I've read/seen posts here a while back where an auxiliary cooler is munted in front of the radiator. I recall one installation where the hoses appeared to run unprotected beneath the car - bad idea!
Anyway, putting in an aux cooler is pretty difficult on our car. There just isn't enough room up-front to make the job easy. It can be done, but expect a lot of time and several skinned Knuckles.
As for the secondary filter, I like the spin-on type or the Magnefine. The increased pressure drop may be a concern, as nobody seems to have a handle on what is permissible with CD4E. Anyway, I would say give it a try, but change the aux filter often.
See the locked post at the beginning of this forum - there is good discussion there.
Good Luck!
Dan B.
96 SE 2.5 auto
Posts: 3,944 |
To add a little to what DanB has stated... As for the cooler - as with most all late model cars, almost all of them use a 195 degree thremostat. With the engine running at that temp and without regular system flushes or fluid changes, you can only expect your tranny to last around 50K! And that is in everyday driving. Drive you car hard and you will cut that almost in half. An aftermarket cooler is a good thing. Even a small one, such as the smaller B&M Super Cool cooler that you can get from Summit for around $50. Anything outside of the rad is a good thing! As for the line filters - If you do a search here using the work Magnafine, you will find tons of threads on the topic of this filter. A few have them installed and as far as I know, they are not seeing any problems as of late with the filter causeing problems with the tranny. Many do agree though that the spin on filter design is much better since it has less of an effect on line pressure. As for what is exceptable line pressure varations - From what I can tell in the Ford service manual, you need to have between 45-63 psi at idle in drive. That would give you something like 18 psi to play with. One problem with the spin on filter is that unless you move your battery to the trunk, you really don't have much room for it anywhere else other than where the battery currently is.  I personally don't have either of the filters. I just change my fluid out like a mad man!!  Welcome aboard and hope that we can help you are your friend with anything else.
Phillip Jackson
`98 Mystique LS
262K+ and counting...
ATX rebuilt @ 151K
Posts: 1,176 |
I have purchased the spin on filter. I plan on mounting it down around the coolant overflow tank. That is close to the radiator fitings for the atx. cooling/filter path is, radiator, external cooler, filter and back to atx.
Posts: 1,603 |
Originally posted by btrautman: I have purchased the spin on filter. I plan on mounting it down around the coolant overflow tank. That is close to the radiator fitings for the atx. cooling/filter path is, radiator, external cooler, filter and back to atx.
You may want to put the filter in line FIRST. It will help to keep the in-radiator and external coolers CLEAN and CLEAR...
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 3,732 |
Originally posted by RoadRunner: Originally posted by btrautman: I have purchased the spin on filter. I plan on mounting it down around the coolant overflow tank. That is close to the radiator fitings for the atx. cooling/filter path is, radiator, external cooler, filter and back to atx.
heres my setup
tranny -> external cooler -> external filter (lying over by the coolant resevoir)
i totally bypassed the stock cooler
Russell
Oval Port 3L Nearly Done
Posts: 1,603 |
You may want to re-plumb your setup so that the filter is the first thing the ATX Oil passes through. Otherwise, every time you service your ATX, you will need to flush the cooler. Whenever your car sits parked, the metal particles in the ATX Oil get a chance to collect in the bottom of the cooler tubes. Over time, this will restrict the flow of oil through your cooler, kinda like cholesterol in our arteries... If you could plumb the filter first, then the oil gets cleaned as it exits the tranny, keeping your external cooler and all of the external plumbing clean, because the filter will trap all of these particles.
You may also want to install a Tranny Oil Temp gauge to monitor things. As your filter fills, and begins to restrict the flow of oil, the temp of the oil may increase, giving you a reminder that the filter needs to be changed.
Pete...
DOB 10/31/2003
DOP 1/2/2004
Posts: 266 |
Just to confuse the issue, here is my two cents: When getting my ATX aux-cooler installed my tyranny man said that the fluid in a transmission will perform best when warm (not hot or cold). The transmission is designed to run at the engine radiator temperature. Therefore, running the output of the aux-cooler through the radiator serves the purpose of maintaining the ultimate temp for operation. Don't forget those COLD winter days.  AND: if you are getting metal flakes in the filter.. you need repairs made to the transmission.  Gray colored dust is normal and comes from clutch material.
Posts: 1,176 |
Good point made, however in TEXAS........our days for the most part are hot and hot and hot and looong. Typical day of 98 deg is normal. Between my engine running a tad hot, fans working on and off to cool radiator as well as atx, I'm thinking the extra cooler is a relief for me here in Austin. Now I would be the first to admit that if I were in say Bangor Maine....things would probably be a little bit different!
Thanks, Bob
Posts: 1,603 |
Originally posted by mr_froge: AND: if you are getting metal flakes in the filter.. you need repairs made to the transmission. Gray colored dust is normal and comes from clutch material.
In any OTHER transmission I would agree with you, but we are talking about the CD4E.
THE CD4E DOESN'T HAVE A FILTER !!! All it has is a Debris SCREEN... Why do you think we are all blowing up transmissions???
Pete...
DOB 10/31/2003
DOP 1/2/2004
