i too would say it's a bad cv joint. that's usually what they do when they go bad (make a grinding noise when you go around a turn). try looking inside your wheelwell to make sure there is nothing hitting your tire. after i put a new set of rims and tires on i had a piece of plastic hitting the tire and it only happened when i went around a sharp turn.
