Hi Guys...My problem started yesterday. I drove my car into work, which is about 45 miles, and it didn't really heat up at all .The temp guage would only move slightly, it would occasionally touch the left line of the normal range, but that's it. The heater wasn't blowing very warm air either, which I suppose makes sense. I drove my car home tonight, and it was doing the same thing, only about 25 miles into the ride my Check Engine light came on and stayed on (even after shutting the car off a couple of times and starting it back up).
I checked the FAQ and didn't see anything on this, so I guess I probably just need to bring it into the shop. Just curious if anybody had any ideas though.
1998 SVT, 80,000
Thanks!
-Josh
1998 Black SVT 1992 SHO www.CVBOYZ.com
H
H
1998 SVT, 80,000
Thanks!
-Josh
I would first try the thermostat. If it is was stuck it would explain why the car isnt heating up, and why you dont get hot air.
It is very easy to on Contours.
As for the CEL it would be my best guess it is related and has something to do with engine not reaching operating temperature. If the computer sees the car has been on for a while 15 minutes lets say, and it is still at 300 degrees it will throw a CEL because it knoews it should be hotter.
F
F
I would probably guess that your thermostat is stuck open...start the car and see if u feel coolant flowing through the upper hose immediately on start-up...if so there's your problem..the thermostat should only open after reached whateva temperature its suppose to open at...of course the car would have to be cold...like the first start up of the day to be sure.
98 Silver Frost EO 90 Grand Am H.O. Quad 4 300,000+ miles
Thanks Guys...I hope that is what it is. I just replaced the thermostat about a month or so ago, but I guess that doesn't really mean much. It's going in the shop today. I hope the CEL is related to the engine operating temp. also.
Thanks again!
-Josh
H
H
Not trying to make you look dumb here if you did, but are you sure when you installed it you put it back in the same way it came out?
Also did you check your antifreeze level, after replacing the thermostat it will drop for about two weeks until the air is out of the system that got let in.
