It is possible to take the regulator off with the alternator still on if you have small enough hands, but you'll probably have to take the Y-pipe off to make room. There are four screws with the star type head holding it on, and be careful not to undo the two that hold the brushes on inside, you don't want them falling loose into the alternator. Like someone said before, I guess you can get your charging system tested at Autozone. I have a problem of my own if someone can help. My alternator went out and I tested my battery with a voltmeter with the car running and it wasn't putting out what it's supposed to. So being poor at the time, I buy an alt. from a junkyard. I tried switching out the brushes and regulator from the used junkyard one into the one already on the car. It helped a tiny bit but not enough to keep the battery charged after driving for a long time. So I put the junkyard alt. on with the brushes and regulator that was on it before. My car charges now, but I can't leave my car sitting for over six hours because something drains my battery. So I've been unhooking my battery cable when I know I'll be leaving it sit for a while. This drain started only after alt. troubles, and I checked fuse by fuse to see if the power drain would go away and it didn't. I think it was something like a 1.25 volt drain.
So, can this be caused by that 175 amp fuse?
If so where is this fuse?
Or, can a bad regulator do this? I know the brushes are good.
Leaky diode? Suggestions?
Thanks, and sorry for long post.
~Paul
