Posts: 8 |
What benefits will i get and what else will i need? I have ST200 Bellows and a Piper X Induction Kit.
MK2 Mondeo V6 Ghia in Panther Black. Now with ST24 Alloys! Piper X Induction Kit,
Trip Computer, 3.0l TB, Ford Racing leads.
V6 Waterpump King
Posts: 5,810 |
The 3L Taurus throttle body is the same size as the SVT throttle body. It will be just like any similar engine running a 60mm throttle body.
See My Mods
Posts: 21,197 |
The 60mm on post 2000's won't even bolt up w/o major modification as well.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 9,602 |
The SVT uses the 3L base casting but everything after that point is completely different. (machining, reverse rotation, air-bypass, linkage, etc)
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,508 |
Originally posted by DemonSVT: The SVT uses the 3L base casting but everything after that point is completely different. (machining, reverse rotation, air-bypass, linkage, etc)
I guess that would explain why my TB has 3.0L stamped on it then.
1998.5 E1 SVT Contour #5482/6535
Posts: 5,810 |
All easy [censored] to fix!
If I can take a MAC 70mm and adapt it to work well, then you know a 3L Taurus TB is no problem.
See My Mods
Posts: 9,602 |
Actually it is easier to make the 4.6L Mustang TB work
2000 SVT #674
