Posts: 26 |
Does anyone know where to get clear corner lights for a 95 ford contour. or does anyone have any for sale?
Posts: 4,294 |
When, I get around to buying propaine, I will go back out to the garage and finish up the set I was making, not the best out there but I think they are pretty good.
95 SES Sold
99 SE Sport Sold
99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
Posts: 2,426 |
Originally posted by LXValdivia: Does anyone know where to get clear corner lights for a 95 ford contour. or does anyone have any for sale?
Here's what I was told when I asked about them:
1. You will need a small drill bit, small screwdriver, long nose cutting pleirs and some silicone sealant 2. remove head lights 3. look for the two tabs that are used to insert the reflector in the housing. 4. drill a small hole directly under the tabs and push up with the screwdriver or anything long and pointy. 5. when the reflector pops out try not to let it roll around too much in the housing--it will scratch the inside of the lens 6. position the loose reflector over the bulb opening, crack and shatter the reflector with pliers into little pieces and shake them out. run some compressed air into the bulb holes and blow the little pieces out 7. use the silicone to seal up the drilled holes-this will prevent the lights from building up condensation on the inside
I haven't tried this yet but as soon as I get my replacement headlights from Bill Jenkins, I'm gonna try on the old ones. They look real good without the orange reflector. Good luck and welcome to CEG. Lot of good people here.
Posts: 249 |
wa2tuff...
I am pretty sure that only works with 98+ Contours, pal. He's got a 95. He'll need to separate the lense from the housing and sand away the orange reflector...
There's a difference between a Euro and a Ricer...
Don't cross the line...
Anything-Goes C.C.
Co-Founder
Posts: 185 |
True Dat.
God graced us with intelligence, let's use it.
Posts: 4,294 |
Originally posted by auiotour: When, I get around to buying propaine, I will go back out to the garage and finish up the set I was making, not the best out there but I think they are pretty good.
are they pre98 or post97
95 SES Sold
99 SE Sport Sold
Posts: 26 |
they are pre 98 corner lenses
