The TCS (Traction Control System) uses the ABS to brake a wheel that is spinning more that the others (-knows from monitoring ABS sensor inputs). It also will reduce the throttle opening (Thats why Ur gas-pedal cable goes 'way round to the front passenger side and dissappears into the
"box" behind the headlight before re-appearing and heading back to the TB!). Kinda goofy setup.
