#875192 02/17/04 03:55 PM
what does it mean if the CEL starts blinking while you drive???
98.5 Black SE ATX S&B filter, SVT MAF, optimized SVT TB, mesh grille, removed orange reflectors, painted rear reflector, gutted pre-cats, optimized SVT LIM, 19lb injectors, resonator removed cant afford an svt but lookin for 1 in nc
#875193 02/17/04 04:16 PM
Misfire. Don't drive until fixed.
1998 ContourLX V6 ATX Cats Gutted+MIL Eliminators Grandma gave me the finger
#875194 02/17/04 04:25 PM
H
H
Misfire, problem should be attended to asap.
From Service CD:
Misfire type A:
Upon detection of a Misfire type A (200 revolutions) which would cause catalyst damage, the MIL will blink once per second during the actual misfire, and a DTC will be stored.
Misfire type B:
Upon detection of a Misfire type B (1000 revolutions) which will exceed the emissions threshold or cause a vehicle to fail an inspection and maintenance tailpipe emissions test, the MIL will illuminate and a DTC will be stored.
The DTC associated with multiple cylinder misfire for a Type A or Type B misfire is DTC P0300.
The DTCs associated with an individual cylinder misfire for a Type A or Type B misfire are DTCs P0301, P0302, P0303,
P0304, P0305, P0306, P0307, P0308, P0309 and P0310.
Note:
MIL = Malfunction Indicator Light = CEL
DTC = Diagnostic Trouble Code = CEL code
#875195 02/17/04 04:30 PM
this only happened after i put on a 98 svt lim that does not quite close all the way would this do it?? also changed the front crank seal but that should have nothing to do with it right??
#875196 02/17/04 05:52 PM
H
H
Originally posted by gearhead98:
.... also changed the front crank seal but that should have nothing to do with it right??
Best to check last item fixed, adjusted, modified, etc, for source of new problem. In this case checking crank position sensor appropriate since missfire usually ignition related.
#875197 02/17/04 05:54 PM
N
N
Get out of there!! Get out of there!!!
Sorry I had to do that...
