#871604 02/13/04 08:07 PM
Anyone installed one of these in thier tour? i just got this one on ebay and its big. i dont understand where the hell this is going to go. do i have to cut a hole out, stick it in and bolt it? im clueless...thats the only think i can come up with...anyone?
'99 ČoňtôúŔ SE Kenwood KDC-MPV7019 AudioBahn AW1206T Flame Q Sub AudioBahn 1300HCQ Amp Blue LED Switches and HVAC
#871605 02/14/04 03:48 AM
um
dont all contours come with a trunk opener? its the little lever down by your left foot...
i think you should rig up the passenger headrest with it and hit the button to whack passengers in the back of the head with the headrest!
-Matt "Pain heals, chicks dig scars, and glory lasts forever!" will do/pay just about anything for the following parts: CF sunroof glass replacement OEM CF trunk Non OEM style cf or fiberglass hood not the cf1 design
#871606 02/14/04 05:10 AM
Originally posted by Speed Demon:
um
lol that would be good stuff.
95 SES Sold 99 SE Sport Sold 99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
#871607 02/14/04 05:29 AM
F
F
Is this aftermarket or a Ford package part no.?
F8RZ-63431B04-AA is supposed to be a spring popper, however it's one of those "round-to-its" that hasn't happened, yet.
TNX
Paul
Paul 98 Mystique LS 2ea (07/97)(08/98)
#871608 02/14/04 03:47 PM
Yea, I've put one of those in. It was in my dad's '97 Corolla. No, you don't need to drill any holes except for maybe running wires. The part on the solenoid that has the bolts wraps around one of your trunk frames, and then you tighten down the bolts. Then find a place on the latch to hook up the metal cable too. Give it just a touch of slack so it doesn't pop your trunk with every bounce of the car. There's should be a little nut looking thing that has a hex screw in it. Thread the metal cable through it and tighten then hex. Oh yea, and don't use that little 3 way wire tapper thing. They're the crappiest thing that anyone has ever invented. Typically, they'll work for a while, and then they'll start to corrode, or just break all together.
Hope that helps!
Jonathan '96 Contour Zetec MTX 208,XXX miles
#871609 02/14/04 04:12 PM
N
N
but if you pop it open, won't it just slam back shut? Our hoods don't have "pop up" capabliltiy. My wife's Honda's hood pops up when you pull the lever.
Mine just stays down, sometimes I've driven with it unlatched...
#871610 02/14/04 05:06 PM
Well, mine does that yes, but if you just walk up you can lift it up. Or there's a trunk popper deal that some people have installed.
Hope that helps.
#871611 02/14/04 05:11 PM
um
i have that, but im going to cut that wire. i just installed a remote starter/alarm this week myself and i want to hook it up to my remote ONLY (besides the key). so if my car does get broken into, they aint stealing my $1k system...
Hope that helps!
Well i took out the black plastic piece where the trunk latch is, theres metal all around it. im assuming i need to cut a hole and put it inside that.
Hope that helps.
That helps quite a bit, i was wondering what i could do so it stays poped open instead of hoping its open. lol.
Now i just gotta figure out how im going to mount it. cutting the metal will suck.
#871612 02/16/04 12:07 AM
Most of the problems with wire taps are due to the following:
1)It is important to use the correct one. Blue 14-16 gauge, Red 18-20 gauge. It can be hard to tell what the wire gauge that you are tapping into is.
2)There are cheap ones out there. Get ones that are UL/CSA listed like the 3M ones Wal-Mart sells and it'll be good. If it is of a design that will corrode (in dry conditions) or fall apart, it won't get UL approval.
If you must use one of these in a place where it will get wet, putting some silicone dielectric grease into it before installing it will prevent corrosion.
#871613 02/16/04 01:01 PM
personally i wont use wire taps. they expand and contract then get loose and give problems. best way to to do it splice into the wire, then tape it w/ 3m electrical and put a zip tie on it. i do it all day at work installing car starters. T-taps suck.
