#71087 12/06/00 06:07 PM
I was wondering if you can use the factry amp w/ a new deck. Im new to the whole sound upgrade thing, so all help is needed. I have the factory sound system installed right now on my SVT. Although I did replace the speakers w/ Pioneers
1998 SVT Contour
Silver/Midnight BLue
1673 of 65355
00' SVT Rims
KKM Pedal Covers
KKM Sill Protectors
Mobil 1 5w30
K&N Air Filter
1998 SVT Contour
Silver/Midnight Blue
1673 of 6535
00' SVT Rims
KKM Sill Protectors
Mobil 1 5w30
K&N Air Filter
Mobil 1 badge(from the cobra R)
50% tint
~100,000 miles
I don't think it would be a good idea. You would be keeping the weakest link in the factory system. Any high-power deck from Sony, Clarion, Alpine, Pioneer, and Nakamichi will sound better by bypassing the stock amp.
Dave
Well, then can you add another amp to the factory deck. I like the way the factory system looks, and I dont want to worry about theft
1998 SVT Contour
1673 of 6535
00' SVT Rims
KKM Sill Protectors
Mobil 1 5w30
K&N Air Filter
50% tint
~100,000 miles
i tried to just use the factory head unit but to my dismay i was not happy ao i went out a plunked down 500 for a alpine cda7864 it is a great unit and it has built in crossovers and is rated at 60x4 max but the neat thing is it has a v series amp not the cheap sh!t you see in most h/u'sit sound grwat i am gonna get a componet set for the front and some 6.8 plates for the rear
98 se mtx
k&n air filter custom short shifter
intake res removed
SVT Exhaust shoshop off road ypipe
svt clutch pres. plate ,flywheel, and trans
SVT gauges
SVT front bumper
SVT wheels
fogs /parking
airbox baffles removed
V
V
I'm running an Eclipse 5303 head unit with everything else stock in my SVT 'tour. The sound improved by 100%. All the amps and speakers are factory. The 5303 has no preamp, so all the power is from the stock amp(s).
98 SVTs
Cobra and E1
mods? (YES)
Good luck getting any sort of answer to this question. I have tried several times to get an answer to this, but the only suggestions I ever get are to upgrade my HU. I don't believe anyone has ever sucessfully done this. Personally, I tried, but I'm not sure what type of output the factory HU is giving. It's not a "normal" pre-amp out. When I was testing, I tripped my amp on the known correct wires several times. I also blew 2 factory speakers (no big loss ). So, unless anyone can give you accurate information on the wiring outputs on the factory HU, I don't recommend this configuration. I can, however, give you most of the wiring schematic if you need it. I just don't know what type of connection is between HU and amp. Hope this is useful.
98.5 Tour SE Sport 2.5 ATX
Mobile 1
80W low /100 W high beam... in transit
Mobile 1 / Purolator
Bosch Wiper Blade/Arms
60W low /100 W high beam
Clarion DB315 HU
Blaupunkt ODx663 Front and Rear(in progress)
Sony 4045 Amp
"New" cupholders
you could find out if a mach amp would work it might seeing as most fords have the same connectors not sure what this would cost
98 se mtx
intake res removed
SVT gauges
SVT front bumper
SVT wheels
fogs /parking
You could always buy the adapters that convert speaker level outputs to low level RCA outputs. I believe in order to do this, you will need to do it after the factory amp. I guess the only problem you will encounter is that you would only be amplifying the weaknesses of the factory amp. It would give you better dynamic range, but the THD would be basically equal to the factory amp.
I don't think there is a harness to convert the signal from the HU to an RCA, but it would be nice.
Moderated by  dnewma04_dup1
