I have several subs from previous installations to intall in my Mystique. I am thinking of using my Boston Pro 12.5 LF. I also have an Infinity Beta 15 DVC that would fit. Does anyone here have any experience with these two subs in a Contique? Thanks in advance.
------------------ '98 Mystique LS Duratec, 5sp Pacific Green Stock for now
'98 Mystique LS Duratec, 5sp Pacific Green Custom Single Exhaust (no resonator and one turbo muffler)
There is no question that the Boston is definitely the superior sub. It is not real effecient, though. What kind of amp will you be using? if you have a lot of power on tap, use the boston, if not, use the Beta.
I will be powering it with an Xtant 3300c. This will put about 360 watts into the Boston or the Infinity. The Infinity is definitely more efficient. It will also play a lot lower than the Boston. But the Boston wins on sheer output.
Well, the Boston would only be louder if it had much more power. Given equal power the infinity should be louder and maybe lower, but that is more dependent on the enclosure than anything else. If you had a 1000 watts available or if your goal was quality sound and not max output, I would go with the boston.
