#870128 02/12/04 06:08 AM
9
99ztech Offline OP
9
I am getting ready to put on an intake and exuast. Is CTA the best intake????
And I am think of starting at the flex pipe. Going to dual
2 1\4" pipe into 2 hi pro mufflers.
Any sugestoins??
99 Zetec Neon under body Removed ding guards
#870129 02/12/04 06:14 AM
2003 Subaru WRX some mods Even if you don't have the answer, you certainly have to admire the problem. aka ZetecRacing
#870130 02/12/04 08:07 AM
I
I
i'd say you're off to a good start...
#870131 02/12/04 04:09 PM
F
F
Great idea on the exhaust but hp gains will be minimal if any unless you get a header and high flow cat to go with it,only because your stock header and cat won't be able to flow anymore than they already are.Idealy you want same diameter pipping from the collect to the cat for optimal flow and then you could possibly reduce pipe diameter to what you want if you want. If I'm not mistaken you could actually lose some hp because stock exhaust systems are desinged for optimal backpressure and flow going to bigger diamiter pipping after the cat may hinder pressure build up in the bigger pipping resulting in a loss of power.Do the whole system and you'll be doing great.Or bump up your hp to increase flow.
REDLINING IT ALL THE TIME 1998 mtx zetec contour 17.1 @79mph open element air filter ford 9mm racing wires dtm style exhaust
#870132 02/12/04 05:01 PM
9
99ztech Offline OP
9
I am going today to get the exuast priced. I will let you know what I found out.
#870133 02/12/04 05:26 PM
Used SVT Exhaust, cheap, good sounding and is seck-say as hell
www.ChicagoCEG.com 2006 White Grand Prix
#870134 02/12/04 08:48 PM
9
99ztech Offline OP
9
I got a price
2 1/4 from cat.
2 hi pro mufflers
2 reactave polished stainless tips
$340 installed
#870135 02/12/04 08:51 PM
I
I
not bad I guess
hope its mandrel bent and aluminized steel atleast, also...
#870136 02/12/04 10:02 PM
9
99ztech Offline OP
9
it is
nothing but the best for my tour
Moderated by  Loco4G63
