#869245 02/11/04 03:29 PM
Z
Zintac Offline OP
Z
Ok here is the deal.
I'm haveing a realy bad vibration/noise in my front end, the they bolth increse with the speed of the car and it gets realy bad around 60 to the point it feels like the front end is gonna fall off the car and it gets realy loose also. It sorta sounds like a tire rubbing/moaning sound but there is no evadance of it. Also the noise go's totaly away when i turn to the left(about 30deg or so or more on the wheel)but if i turn to the right the noise/vib. gets much worse. So my question is, has any one had this problem and if so whats the answer?
Also the tires are brand new and it has had an aligment.
I have on the front and back.
Stock rims
Mich Pilot vr3
koni adj.
eibich springs
Sorry about the speeling.
Thanks in advance.
Zintac
#869246 02/11/04 04:24 PM
Wheel bearings. Jack up the front end of the car and see if you have a lot of slack in one or both front wheels.
#869247 02/11/04 09:38 PM
Z
Zintac Offline OP
Z
Thanks for the advice, ended up replaceing the driver side wheel berring. Car now drive and handels like new.
Thanks for your sugestion
Zintac
#869248 02/12/04 12:48 AM
You're quite welcome. After 969 posts, I finally guessed one correctly.
Glad you got it fixed. It sure didn't take you long to get the repair done.
