#868406 02/10/04 09:13 PM
Does anyone know the shift points on a 95 contour 4 cyl MTX. I need to know by the speed because i do not have a tach on my tour.
#868407 02/10/04 09:55 PM
Z
Z
Did you check the manual?
- Zack WANTED: T-Red HEATED Side Mirrors FOR SALE: 4 14" Alum Alloys and Nearly New Avid H4s Tires w/ Center Caps 2000 T-Red SVT 1995 LX V6 MTX (RIP)
#868408 02/10/04 10:09 PM
Shift before it sounds like it's gonna explode. j/k
Acceleration:
14;25;33;48 normal driving 12;20;29;40
Though you can probably shift higher if you really gotta get somewhere. And for about $25 you can get an instrument cluster from a junkyard w/ tach.
#868409 02/10/04 10:12 PM
A car with a manual tranny and NO tach!!!
How absurd...
Your best bet is to measure your tire diameter and then figure out what the MPH is in every gear based on tranny gear and final gear.
Very simple really!
#868410 02/10/04 10:13 PM
H
H
Would putting in a tachometer cluster into a non-tach work, I dont have a tach either but want one.
#868411 02/11/04 08:59 AM
CEG road warrior
CEG road warrior
Yes it will work.....just try to get the same year, same engine and you will be fine.
#868412 02/11/04 10:05 PM
Z
Z
Also, I believe only the Mystiques have I4's with a Tach, so if you're searching, take a look at them.
- Zack
#868413 02/11/04 10:21 PM
H
H
I'm not trying to second you guess you here or anything but I got a few questions.
If I put that in with all the lights, brake, oil, CEL, seat belt, battery, and the O/D etc., all still work or will I have to move bulbs around?
Also my other question is how will it work since it wasnt designed with a tach in it. The connectors back there and just fit into both cluster or something?
thanks
#868414 02/11/04 10:32 PM
Actually some zetec Contours had tachs as well, even ones with autos... It's all plug and play.. Just buy the cluster for about $25 at local junkyard or www.car-parts.com (specify your exact model) and remove old cluster (some screws can be hard to get to, but not a big deal) on 96+ there are two connectors back there, connect them and you're good to go. For 95s, it may be different.
#868415 02/12/04 12:15 AM
or just buy one of those ricey moster tachs and bolt it to the top of the dash. they go to 10,000 rpm, which will leave you some room incase you do some not yet invented mods to the contour.
#4559 of 6535 born on Feb 17, 1998 Black 1998.5 CSVT FOR SALE [cleaning house]: SVT rear swaybar. Reasonable offer and its yours!
