#867461 02/10/04 12:08 AM
N
NJE96SE Offline OP
N
I have researched this, and I think I have it right - I am just looking for a confirmation from the knowledgeable people round here.
Downstream O2 sensors are used solely for monitoring the pre-cat efficiency, correct? The upstream sensors help coordinate the MAF with the fuel injectors by telling the PCM if the exhaust gas is rich/lean. The downstream sensors get a value for O2 concentration that the PCM uses to compare to the upstream sensor value and determine if the pre-cat is oxidizing the nasty stuff. Am I semi-correct here?
The reason I am curious is that I have a downstream sensor that is bad. Can I get a set of MIL eliminators (a pair is cheaper than a single O2 sensor) and plug those in and forget about downstream sensors for good? Do you need a functioning O2 sensor for the MIL eliminators to work?
Thanks in advance for you help.
06 Mustang GT - stock 96 SE V6 5spd Midnight Red - 15.9 @ 86.8 150K miles Mods: Bilstein struts, H&R springs, Borla Cat-Back, Brullen y-pipe, Gutted Precats, SVT UIM+LIM+TB, K&N FIPK, , DMD, Magnecor KV85
#867462 02/10/04 01:06 AM
The MIL eliminators depend on a functioning O2 sensor to work.
How did you determine that your downstream O2 sensor is bad?
#867463 02/10/04 01:18 AM
N
NJE96SE Offline OP
N
CEL, went to Autozone.
#867464 02/10/04 01:27 AM
Do you remember what the code was? If it was a P0420 or P0430 it's very likely not the downstream sensor that's the problem..
#867465 02/10/04 01:28 AM
H
H
Mine went bad to, got it fixed Friday though. Also had the mechanic clean the MAF.
Did you get code PO171- to lean bank 1
That is what I had and he said the problem was the downstream O2 sensor.
#867466 02/10/04 01:54 AM
N
NJE96SE Offline OP
N
If I remember right, it was P0141 (bank 1, sensor 2). I got it right after replacing my y-pipe. I think it may have been damaged during the install.
#867467 02/10/04 02:11 AM
MIL eliminators will most likely not help then. They are designed to get rid of P0420/P0430 codes, and require a properly functioning downstream O2 sensor.
