My 95 Toyota Tercel is acting crazy! I tried to start it the other day, it would run for about 2 seconds and die. I finally got it running by barely holding the throttle down and finally got it to stay running. I had to warm it up or it would die when I let off. I drove it today, no power at all... If i pressed the throttle down the power went away and it would stutter, I let up and barely hold it down it ran ok. almost like when you got a carb car and you lean it out by barely holding the throttle down. I pulled the plugs, they were almost black (rich) I replaced and still had a cel. Code p0105, which is an electrical circuit problem tried to reset the cel no luck, it also seems to suck gas now. This car has no rotor cap... Im thinking my timing is wayyy off or something is wrong with the electrical ignition system. What do you all think?
Ryan
Ryan
