Dylan Offline OP
Hey guys, I did a search but it didn't yield any results. My parking lights, tail lights, and interior lights have all stopped working simultaneously. I am assuming this is a blown fuse but I cannot locate which fuse needs to be changed. I have check the Owner's Manual and the Factory Service Manual but I cannot find any fuse that is linked to these lights. Can anyone help me locate which one needs changing or if this isn't a fuse issue? Thank you in advance.
-Dylan
You may want to post in troubleshooting, not the zetec maintenance forum..... And why not just test all the fuses you can find, a fuse tester isn't but just a couple of bucks. Though it could be some sorta short.
in the fuse box under the dash (i have a 98) they are numbered. in teh owners manual, it should say which number is what. i just had the same problem. good luck.
hey man i had the same exact problem the only thing that worked was my brake lights but not the running lights at night and the dashboard and all those other things like that it was a recall for the switch knob if you look at the connecter it has a problem with melting part of the connector got mine fixed for free look in to it it should be on common problems here on the website thats where i found info for mine
1996 Ford Contour GL MTX
so did you check in to that problem with the connector behind the light selector switch?
just check all of the fuses... best/easiest/least hassle to it... pull one out check it put it back in and so on...
-bRaD
1996 ford contour sport
Originally posted by Cookie Monster:
Sometimes I just start slowing down and glare in the rearview and say "yeah I could go for an SVT rear". Jackasses.
