Posts: 511 |
I already know that there is a hole in the firewall under the wiper cowel but don't want to go through all of that hasstle taking it off. I heard some people drilled a new hole but was wondering how I would go about doing that? How do I find the right spot, and what side do I drill from? I know i'm going to need a grommet and silicone to seal the hole once the 4 guage wire is in it. I just need help with the location of the hole and what side to drill from. The only thing I'm afraid of is hitting something important while drilling. Thanks everyone.
AIM...BKapp17
98 T-red SVT
Steeda
Gutted Pre-cats, no resonator
Painted Dash
Angel Eye Fogs
Painted Chrome ring / headlights
Looking for a t-red pre98 trunk lid
Posts: 509 |
I installed 4 guage yesterday, and it took all of 10 minutes to pull the wiper cowl and reinstall it when I was done. It probably would have been even faster if I hadn't been shivering like whoa...
I would definitally say that this is the safest most reversable method of installing the wire.
Getting a drill up behind the firewall will be a royal pain in the ass from either side, and there's wiring and whatnot you don't want to hit on both sides.
don't drink and drive.
Posts: 2,382 |
Agreed, I would never drill a hole to the outside of my car, especially the firewall. The cowl isn't that bad. Remove the wipers, the cowl, the rubber "stopper" and you're set. It's not a hassle at all.
Good luck!
"Fear is the little death."
Muadib.
Posts: 1,359 |
I'll be trying this wiper cowl thing out for myself this weekend....I'll let you know how it turns out.
98' Contour SVT
#607 of 6535
05' Mazda 6s
Audio/Visual enthusiast because it's one of the many things I went through 4 years of hell for
Posts: 9 |
I drilled my hole behind my fuse box under the driver side dash , the fuse box is very e-z to remove.
00 svt contour
black
B&M shifter
Posts: 3,064 |
If you have had an alarm installed they would have drilled through the firewall mostlikely. Just follow the wire(s) coming from your alarm horn. Just another option.
Posts: 1,359 |
I installed my power wire last night and went through the wiper cowl grommet like everyone recomends doing. It only took about 10 minutes and it makes for a clean install too. I took some pictures, so as soon as I upload them I will post them for you to look at.
98' Contour SVT
#607 of 6535
05' Mazda 6s
Posts: 4,140 |
Is there a how-to on that wiper-cowl hole?
Posts: 2,382 |
if you take off the wiper cowl (torx screws on the under hood part, regular phillips on the exterior surface, covered with small round plastic clips)
You'll have to take off both sides of the cowl (it's two pieces). Look in the hole by the drivers side and you'll see a round black rubber cap. It's against the firewall, and it unscrews. Poke a hole in the center of it, and run the wire through it. Then put it all back together again.
The wire coming through the firewall will be high up by the brake pedal, have a buddy look for it as you pass it through.
Good luck!
Muadib.
Posts: 4,140 |
Thanks, now I can get rid of that 20 GA coming off the radio harness...
