Page 1 of 3 1 2 3
#863702 02/05/04 06:20 PM
so i just got done reading all that i could by searching, and i'm still curious if i should get a cap
right now i have a kenwood kac 729 amp, its 300watts brigded to a 12" kenwood exelon,
i have another amp and sub (both the same) on the way, and just was wondering if it would be a good idea
edit: i was thinking of going w/ the one from knukonceptz
98 Silver V6 SE Sport K&N w/ heat sheild, Elky mesh, fog-light mod, knauberized
#863703 02/05/04 07:11 PM
well, it's not a bad investment to make.
#863704 02/05/04 08:40 PM
capacitors are gr8 inventions. but they are primarily used for systems puching upto and over 1000 watts. i do have a friend, however, who put a capacitor on a system with 600 watts on his chevy monte carlo. he had a problem with his light dimming when the system would hit hard. since he put it in, he has had no problems. My system in my CSVT has no problems at all w/o a capacitor and i runn around 750 peak power.it's up to you wether to get one. the people who installed my system said it wouldn't be worth it unless i ran over 1000 watts. our cars don't have the power drain problem like some others. but getting one now will negate the need to get one later if u decide to upgrade ur system.
2000 Ford Contour SVT-t GT28R - 287whp/314wtq @ 11 psi (very little tuning) Cardomain Page Photobucket Page *Formally XxColdAzFireXx*
#863705 02/05/04 09:30 PM
to edit my last post; 300 watt rms
well, i think ill get one, even if i dont really need it now, i know itll come in handy later
#863706 02/06/04 12:10 AM
N
N
I have a question also...
I have my capacitor hookd up but my lights still dim... I have checked the connections and they seem all good... what could be wrong?
Steve
Steven. L. Benthal Jr. 98 Mystique: Meshed Grille & Pioneer Sound System
#863707 02/06/04 12:35 AM
Steve
You can more than likely solve the problem buy simply improving your batteries ground.
2000 SVT Black/Tan #1633/2150 (a few mods) Alpine: CDA-9835, MRV-F540, MRD-M550 PG: TANTRUM-X 6.5 COMP all around. Some people wear Superman pajamas. Superman wears Chuck Norris pajamas. CEL currently: Off
#863708 02/06/04 07:11 PM
Steve
I was looking at the pictures of your setup, and I noticed the amp and the cap are on opposite sides of the trunk. I just installed a cap, and the instructions said to keep the power wire between the amp and cap less than 18 inches.
#863709 02/06/04 09:09 PM
N
N
I'm thinking I need to get it charged... where can I get it charged for free?
STeve
#863710 02/07/04 12:59 AM
You can charge your cap on your car battery... my RF cap came with a charge card with a couple of lights that tells you when its charged/discharged
1999 SE White AVH-P6500DVD Infinity Reference 6500CS Pioneer 5x7s Punch 360a2 Punch 500a2 Adire Tempest in a custom sealed 3.4cuft box Modded Xbox Still need Midnight Cloth Headrests... and if somebody has fold down rear seats....
#863711 02/07/04 08:34 PM
STeve
If your cap is connected to the battery, it is charged....lol....
If your lights dim, check all ground and make sure you upgrade you factory ground cable (car comes with a 10awg ground) all you need is 2ft of 4awg and 2 ring terminals. There is a factory bolt under the airbox. That should take care of any problems
Previous Owner of 00 SVT Contour #1077/2150 95 Contour SE '01 3L
Page 1 of 3 1 2 3
Moderated by  dnewma04_dup1
