Welcome (I'm not a Contour, but a CDW27 just the same)...
Thed concensus on the NECO and CEG boards is that your +4s are your worst nightmare. The Duratec engine uses a "waste-spark" coil, meaning that it fires from anode to cathode on the cylinder that's firing and cathode to anode on the cylinder that's exhausting at the same time. This will kill a non-double platinum plug in short order. The Motorcraft AWSF32FS plugs or the equivalent Autolite double plats are your plug to use. Use 2-step colder copper if you're spraying, of course.
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
